0 Members and 263 Guests are viewing this topic.
gyulasun
Quote from: znel on December 05, 2011, 02:43:59 PM
   Bulbs are a good visual representation of work being done but do not represent the actual output.   Just because they are rated at 60 watts in a conventional circuit doesn't mean they are using 60 watts to light.  This method of output is deceiving.
Perhaps a better estimation of the power levels involved can be made by running a 60W or 40W or 25W test bulb separately and directly from the 220V mains voltage and then you can see the difference in brightness between this test lamp and the lamp or lamps driven from the output of the device in question.
This 'comparison' method has already been mentioned, not a new 'method' of course.
EDIT:  just saw the bulb immersing in water suggestion, it can be also a good method of course.
The Observer
Verpies,
Thankyou for your response to my question about the formula that describes the Magnetic Field inside a Solenoid Coil.
Quote1. Magnetic Permeability... a number that reflects the Density and Intensity of magnetic dipoles in a substance (powered by free electron spin.)
        Formula for a Magnetic Field inside a Coil.
                                                            B = (μ0 * μr * N * i) / l    -->    B =   Î¼r * (μ0 * N * i) / l
                                                    - μ0, N, i and L are constants for any given coil with a constant current.
                                                   - μr is the Magnetic Permeability of the material within the solenoid.
                                                   - (99.9 % of all substances have a  μr ~ 1,      Ferros have a μr  ~ 500 to 1 Million)
                            * A Ferromagnetic Substance can Amplify the Magnetic Field of a Coil by 1,000,000 times... no extra current needed !
I'm a bit perplexed that you don't think this formula is important when wrapping wire around a core when it shows such an enormous anomaly.
That is that .0001% of all substances (ferros) amplify the magnetic field of a coil by 1000s to 1,000,000s of times !
All others..  the 99.999 % pretty much do nothing.
I find this amazing.. don't you?
You are correct, that the extra field comes from the Ferro Material. (Field of Coil + Previously Hidden Field in the Core)= Total Field
However to be more precise, the Core's Magnetic Field comes from spinning unpaired electrons at the atomic level.
(see diagram below)
I think you might have surmised what I was getting at with the speaker example.
So I will just make a general statement that encompasses my point.
I would like to know if you generally agree, or disagree with the following statement.
---> "Without ferromagnetic substances, it would take a lot more energy to run things like a speaker or an electric motor."<---
                                         * a ferromagnetic substance is anything that is a magnet or sticks to magnet
Again, thank you for your time.
Best Regards,
                     The Observer
conico
Hi all,
I want to replicate the experiment from Lithuania with caduceus and pickup coil. Can someone tell me where I must connect the light bulb? In diagram is a connection to the middle of the pickup coil but in the movie is not.
gyulasun
Quote from: xenomorphlabs on December 05, 2011, 03:17:56 PM
Can anyone recommend a good site to find replacement/equivalent  transistors?
@Magluvin: What transistor type did you use?
I got a couple of russian transistors but not the KT805AM.
It has an ftrans of 20 MHz and most of the other transistors i come across
only have like 1-3 MHz and a power rating of 30 Watt.
Xeno:
These types have pretty much similar spec.  or bit better than KT805AM:
MJE15028
http://search.digikey.com/us/en/products/MJE15028G/MJE15028GOS-ND/919489
MJE15030
http://search.digikey.com/us/en/products/MJE15030G/MJE15030GOS-ND/919491
xenomorphlabs
Quote from: gyulasun on December 05, 2011, 05:10:53 PM
Xeno:
MJE15028
MJE15030
@gyulasun:
Thanks a lot. Your help is much appreciated.
These models are no problem to get from my suppliers.
