0 Members and 199 Guests are viewing this topic.
Shokac
Quote from: xenomorphlabs on December 06, 2011, 11:49:34 AM
Don't be discouraged. It is understandable that people are struggling to see power measurements and sooner or later someone will do them.
The last diagram you posted is really interesting as it reflects what Kapanadze is doing in the newest device.
Instead of the slitted copper tube he just seems to be using the copper of the output wire itself going through the core of the crossed coil. That wire is most likely being fed with a 50 Hz sine signal (from the PVC box) just like you supposed to attach to both sides of your copper tube.
The power of the sine signal is maybe only 10 Watt. So the current amplification might take place
inside the crossed coil due to a property of that crossed coil in conjunction with the HV excitation.
I speculate that effect to be more related to the electric field of the coil thus increasing the current  in the wire. Such element is explicitely mentioned in TK's patent and referred to as "current amplifier".
I told long time ago, HV take current from air (free electrons). ONLY CURRENT.
Sem is proved!
THANK YOU SEM!
Hope
Quote from: semenihin-77 on December 06, 2011, 11:37:56 AM
Shaw will not hold, I can not for the entertainment of the crowd put the experience if you so blind that would see the truth, I wash my hands. Look for the energy of ferrite, and so on.
It is unfortunate that attitude.
Delamorto
Not to worry Mr Sem77,    please just start a new topic and others interested in your work will be joining your efforts and then builds will follow with proofs forth coming.    There are many inspiring project just now and most can only handle a couple at a time.   Thank you
energia9
Quote from: xenomorphlabs on December 06, 2011, 03:12:49 PM
Nothing to help. It's his right to set the videos to private and so he did.
Future advice is to always save anything that is brandnew as long as it's public, you never know how long it'll be up.
Set up a little test unit. It (and that means ONLY my test unit) runs inefficient. A 15 W bulb barely glows.
But i used a 3055 transistor. Will see if anything changes when i get hold of better transistors.
Also due to the winter i can not establish a real earth ground, which is certainly also a factor.
im sure  no energy device of Teslas kind relies on ''better'' transistors.
Hope
Hey,  That copper tube reminds me of how the Camelot (Greens) motor gets magnetic main field spinning.   Can you see it too?   Wattsup do you see the correlation?  That gap allow the edges to have counter magnetic fields and the attraction is constant no matter what the EMF movement.
AND energia9    "None of us claim to BE Tesla, nor to have his understanding."  So we limp thru as we must.
"It takes a great mind to remain positive, others simply deride due to lack of wisdom."
Today my father passed away, he was 83 and will be missed a lot.  He was so limited the last few weeks that I feel relief for him now that his struggle is over.
Edited "My friends here asked me to share about Dad"
Shokac
Quote from: Hope on December 06, 2011, 03:43:42 PM
NO!, This is topic about Kapanadze.
Kapanadze dont use ferite core or core from old TV.
Go ON Sem!
