0 Members and 213 Guests are viewing this topic.
oscar
Great explanatory video http://www.youtube.com/watch?v=pdsWHRWzYtg, Jimboot.
Thank you.
Quote from: garrypm on December 10, 2011, 02:50:55 AM
Delamorto,
where is the scope connected ?
Quote from: semenihin-77 on December 10, 2011, 03:12:03 AM
Measured with the lamp.
The attached screen shot is form delamorto's video showing the sine wave http://www.youtube.com/watch?v=1dEULZsLORc
The still image shows, that the scope probe is connected across the light bulb.
The sine wave is created due to the impedance of the load !?
Thanks, delamorto
The transmission was a '53 (Johnny Cash)
ronotte
@wattsup
I am in your same situation: my Ventex HV generator (9030D-120)...died...after few hours of good operations that allowed me to run several optimization tests. It died even considering that I took every conceivable attention to not overload it :( Last good setup has been without the connection to center tap secondary. In that case the lamp's filament being incandescence. So now I do not know how to go on as I have TV flyback units...but I lack the old schematics hence not easy to locate the correct connections.
Roberto
mrzlica
Quote from: znel on December 08, 2011, 01:29:33 PM
For anyone interested in making HV capacitors with reasonably high values and not spending a fortune on "store bought" units there is an easy way...
I purchased a few of the "roll up" snow sleds from Amazon ( 4-5 bucks each ) and use a heavy foil for the plates.   The dielectric constant is 4 using these and will handle up to 20kv.   It's quite simple to calculate the 2 plate cap to get within a few pf of what you need.   As an example I rolled one up with a 4" wide x 54" long plate and it came in at 5500pf and is very robust.   It's external size once rolled is about 3" diameter and 6" tall.
I don't know of anywhere you can purchase a 5000 pf 20kv cap for less than 4 bucks...  I've been making them this way for a year or more with very good success with them.   Super easy to calculate and make.
Hello!
Can you please add amazon link for the "roll up" snow sleds.
Thanks
Jimboot
Quote from: semenihin-77 on December 10, 2011, 04:46:16 AM
Transistor 13 007 runs in 2 times worse than the 805, do not use resistors, start pulse from the power supply through a resistor plus 1.3kom.
Thanks Delamorto I'm using the MJE3055 will source some new transistors soon.
dllabarre
A while ago someone posted these would work as well as the 805.
Would these transistors work OK?
MJE15028G
http://search.digikey.com/us/en/products/MJE15028G/MJE15028GOS-ND/919489
MJE15030G
http://search.digikey.com/us/en/products/MJE15030G/MJE15030GOS-ND/919491
Thank you!
DonL
