0 Members and 148 Guests are viewing this topic.
baroutologos
@ ronnote,
i had quite the same luck with mine NST. It was a battery operated 9KV 30mA, that worked splendind in running a Tesla coil. It was running at some 40 watts. Far better efficiency than a ignition coil and output.Till it died. I have paid some 60 dollars or so. after a research, i found out, that Tesla coilers use between their transformer and capacitors (either with FWBR or diode or without all those) CHOKES.
Imagine to burn a 10KW HV transformer due to this!  This is due to HV spikes of High frequency go back to transformer and are able to destroy it, whereas in low frequency it would not happen.
Chokes should be some 100-200 uH and able to handle some current without saturation. Many are using air core coils of equal inductance.
ps: nice vaccum variable capacitor :)
@ wattup,
Sorry about your second loss in a row, but you should really use HV high efficiency blocking capacitors to your hot lead. For added safety, use also blocking cap (e.g. 20 pf 30 KV) and the chokes inductors.
Care should be give when making them, in order windings not to have capacitative coupling between them. (spaced and if on a toroid, isolated since toroids are somewhat conductive)
@ energia,
Get a hold of yourself please. we have repeatedly told that 99,999% of the cases that they claim OU, its not. But this is a hobby site more or less. I have learn this the hard way in case (like me) you initially believed and spent considerable resources in replicating things..
Concerning sem77's case, i find interesting and educative his approach to Kachers. Especially in his last video, his Kacher even with a small ferrite (i assume 2000MM soviet type 8 or 10mm diamm) can run at 2+Mhz, and with great efficiency. I am not able at the moment to do that.. so I learn too :) ... sem77 keep going!
btw, i have ordered some vintage Soviet KT805AM transistors... :) i love vintage things!
Kator01
Hello,
there is one thing I have to add to my photocell-setup which applies only here:
The bulbs you use here under test in a photcell-arrangement must be covered on one side with an aluminium-foil which is painted with a heat resistant black-varnish on the outside. When one compares the light-intensitiy with a reference-sinus-power with this bulb you must measure the temperature on the black side of the foil, because incandescant bulbs dissipate more than 80 % as heat.
If you find during your tests with the Kacher-setup that the bulb stays cool on the black side of the foil then only the light-intensity accounts for the input-power of the kacher. Things then are more complicated but a clear indication that the Kacher spends - based on slayers input-data - 12 Watt for producing a cold light, so far from being efficient < 20 % )
Should the temperature match in both tests then there is hope.
@slayer : add controlled mass of diffrent areas and weight to your yellow clip dangling.
Kator01
joefr
Hi Delamorto great work
Can you please show setup schematic from your last video so we can replicate?
Best Regards
JoeFR
scratchrobot
Quote from: energia9 on December 09, 2011, 11:53:01 AM
You people are constantly being fooled,  Lied to.. Daily...
now i can see through all of these people like glass...
Can you see the truth?
