0 Members and 80 Guests are viewing this topic.
jbignes5
Quote from: Jimboot on December 11, 2011, 04:50:56 AM
here is the vid of the effect, https://www.youtube.com/watch?v=7TI_KGF6rBY
Wait so you are generating that movement from the coil by putting electrodes on the inside of the vortex and the outside???????? It has to be a harmonic response of the coil and the field. Remember the pattern I showed you of the magnetic fields. The high contrast areas are the voltage component but the dark areas are the heavy magnetic component. The magnetic field flows in a spring like shape around the coil in the opposite direction of the voltage and goes out the poles. The negative probe is a virtual ground and it is in the field touching either component and the positive is outside of that field with the coil(meter). Moving the meter around would be a great idea and useful tool to probe the field. I'm assuming we can effect the magnetic flow by having iron guides further away. This might keep the spring like field in a preferred location or rivers(channels). Or we could just leave it as probes but add more, in parallel, of negative leads around the field and see if it gets better.
Have you tried ac current tests yet?
Most exciter type coils have very big fields and now we are seeing this.
xenomorphlabs
Quote from: DreamThinkBuild on December 10, 2011, 08:30:45 PM
Hi All,
I've been trying to visualize what the magnetic field looks like from a caduceus coil. I setup a linear hall sensor and a caduceus coil, 20AWG, connected to a 12v 400watt computer power supply. I slowly ran the sensor over by hand marking from the crossings on paper. Attached is a picture of what the rough field looks. Note that this is slightly less wavy than the screenshot, better measurements are needed. Very interesting shape, if we imagine this field in 3D it would appear to be a radial hyperbolic paraboloid. Minkowski space time geometry comes to mind.
http://www.ma.utexas.edu/users/gilbert/asciimath/QuadricSurfaces.html
I had a weird measurement experience with this coil when placed at certain points near the center of the +/- fields the hall sensor would pickup up a oscillating magnetic wave (+/-/+/-) from a DC input. (huh?) It could be the power supply or interference I just wanted to mention it if anyone wants to do some more measurements. This is a fascinating coil. I'll tinker with it some more this weekend.
Attached also is the circuit I used, very simple. The ugn3505 has a built-in linear amp.
Big Thumbsup !!! You are filling textbook gaps with what you have done.
Very helpful. Thanks.
That "oscillating magnetic wave (+/-/+/-)" part is especially interesting.
It might be just that the meter can't decide which sign to give to a near zero value, but it
can be also indeed a physical anomaly.
Just had the idea that you might wanna try to repeat the measurement with AC from a signal generator.
At first thought it would seem to not make much sense, but i just envisioned the changing
waves and had the funny idea that maybe there is something like a standing magnetic wave resulting from it. Could turn out to be wrong though.
dllabarre
@semenihin
I have a question on transistors regarding my replication
A while ago someone posted these would work as well as the 805.
Would these transistors work OK?
MJE15028Ghttp://search.digikey.com/us/en/products/MJE15028G/MJE15028GOS-ND/919489   or
MJE15030Ghttp://search.digikey.com/us/en/products/MJE15030G/MJE15030GOS-ND/919491
Thank you!
DonL
joefr
Hi DonL
This question was asked several times but no one answered jet.
I get MJE15030 tomorrow and will post how is working in kacher setup.
Currently I am using MJL21194 NPN 250V 16A and it is working OK
JoeFR
xenomorphlabs
Quote from: joefr on December 11, 2011, 10:28:46 AM
Hi DonL
JoeFR
@Dllbare
Used both the MJE15030 and the MJE15028 and they both work as intended in regards
to creating the oscillation/switching.
I am sure that Delamorto couldn't even tell you if transistor XYZ
would "work" too unless he tries them all out.
Just get the MJEs and experiment.
