0 Members and 40 Guests are viewing this topic.
jbignes5
 Please remember guys that diodes are a beautiful thing. They are the one way valve just like in our vacuum pumps. They only take one flow from the fields around the coil. This will preserve one side of the field(electric) and only take the dynamic environmental portion(magnetic) which has been condensed on it's surface. This magnetic portion flows like water in the peeks and valleys of the electric field which is in a screw like spring fashion. A spring made of like polarity strings flowing from the central point radiating out to the environmental field. Magnetics seems to be a condensation of magnetic lines. It has the same rules as water and hydrodynamics under that water. Surface and surface rules becomes very important in this area and electrostatics doubly important.
Mechanics will also play a good role because this spring can be used in the same fashion as real gears and servo mechanisms or even springs. These springs can be routed into a circle and when that happens the magic really starts. Think of the best magnetic bearings in the world running just a field in the shape of a gear. This gear is ran by the field itself created by the coils going around the device. The magnetic portion is sucked into the iron ring and the electric field is free to play. This field is very stiff and is the very lines or ropes Tesla was talking about riding. He learned not only how to make them stiffen but bend then flick the field around the conductors. The fields have texture to them and they interact very mechanically like. Put another gear in the center of the field ring and you have super stiff lines bound by the concentrating rings surface. The inner coils would have tons of concentrated strings holding onto the rotor in the case of the Tesla exciter/generator/motor.
Although I have to say my work with the no bearing Bedini motor was very enlightening when you added satalite magnets. They spun too and I think that the size of each magnet has a ratio of the spin of the smaller satalites when compared to the drive magnet.
I had a chance to edit the picture of the Tesla coil and added what I thought was the correct way to view this field:
http://i128.photobucket.com/albums/p171/jbignes5/kacher_delamorto_2011-10-16addedcomments-1.jpg
Tell me what you guys think..
AbbaRue
@All
I keep reading about a "Kacher" and I can't seem to find what the Kacher circuit is referring to.
Could someone please point me to it.
Thanks!
verpies
Quote from: xenomorphlabs on December 11, 2011, 11:32:54 AM
Could you please elaborate on how exactly you measured the 200Vpp?
For those of you who do not have an oscilloscope and want to measure the peak-to-peak voltage note that it can be done with two fast diodes and two large capacitors connected as shown on the diagram below.
The voltage measured across the two capacitors with a DC voltmeter is the peak-peak voltage (less 1.2V)
joefr
Hi all
Is anyone tried this kacher mosfet driver in Delamorto experiment ?
I found it on this site:
http://teslacoil.ru/devices/pravilnyiy-kacher/
JoeFR
znel
Quote from: joefr on December 11, 2011, 02:14:05 PM
Hi all
JoeFR
Looks interesting, what is the 4 pin chip ?
