0 Members and 36 Guests are viewing this topic.
PhiChaser
Regarding the meters and scopes comment; Have you tried taking measurements using any passive devices like an induction clamp (old school passive I think would work best) around your output wire(s)? Maybe the bulb ends (leads??)?
PC
Jimboot
Quote from: stivep on December 11, 2011, 11:04:09 AM.
So if you have  capacitor connected with one end to  HV wire it will charge itself by closed loop with electrostatic and/or electromagnetic nature.
Wesley
please take to your attention this article send to me by German scientist.
http://www.ndt.net/article/0398/huebsch/hueb.htm
http://www.sumobrain.com/patents/wipo/Method-device-non-destructive-material/WO2011138027A1.pdf
Wesley
Thanks Weley, I will have a look. I've been tinkering with these devices for nearly a year now but this is the highest voltage one and certainly the only one I've had hat will light a large incandescent. 70leds wirelessly no problem, charging caps wirelessly with an av plug, no probs, based on what I'm seeing with the lamp what you say about the cap makes sense. Not sure about the electrostatic connection though. Isn't  what we are looking at here longitudinal waves rather than transverse? The ability to jump straight through insulation, even glass, seems to be a departure from conventional circuits.
Jimboot
Quote from: PhiChaser on December 11, 2011, 04:24:32 PM
PC
hi Phil others have said here that an induction is not reliable at these high frequencies
jbignes5
Quote from: Jimboot on December 11, 2011, 04:34:44 PM
Yeah the through the dielectric shielding is normal and is what is breaking coils. The only way Tesla could fix that was maximize the dielectric through the use of oils in mass wound transformers.
A Tesla coil works a tad bit differently when dealing with those voltages. It steps it up gently as you go up the coil. Smaller steps(more winds) are the key. Hence why you don't need the oils. and yes Tesla talks about how even glass can be perferated by this effect. As if glass got or had a dielectric breakdown.
woopy
Hi Jimboot
thank's for sharing your work
here an attempt to replicate your experiment
i used my Slayer main (L1 ) coil and added a Caduceus L2 coil
i got very good results but far from your fantastic lighting of a incandescent 25 W (240 volts ) bulb
So my question is     is your incandescent bulb really burning (with heat ) or is it a plasma effect all arround the filament ?
thanks
And good luck at all
Laurent
http://www.youtube.com/watch?v=6ocPYYEv37g&list=UUi3fFZN1pwHTyM8H_nSxerg&feature=plcp
