0 Members and 289 Guests are viewing this topic.
hartiberlin
So,
how do you all think this circuit
http://www.youtube.com/watch?v=VZtvJy3cRzo
works ?
Inside the PC power supply there is probably some kind
of square oscillator that pulses an autoignition coil
to produce High voltage which charges up a capacitor.
Then when the breakthrough voltage of the spark plug is
reached, it can fire in pulses
and drop the charge of the other capacitor from inside the power supply case
into the external coil and capacitor, which forms a 50 Hz LCR resonance
circuit.
The bulbs are just the the R load of this LCR  circuit.
The other 2  coils on the ? aircore ? there are probably only for the feedback to control
the right pulse phase relationship and for impedance matching from the load
impedance load to the higher impedance sparkplug output.
So the 3 coils is basically an impedance and feedback coil
transformer and the main output coil is one part of the LCR resonance circuit.
Can somebody see, how all the coils and the external cap is connected from the video ?
Many thanks.
hartiberlin
Hi All,
I just compared the videos from user:
http://www.youtube.com/user/teofiliuss
to user:
http://www.youtube.com/user/replikator1969
and the new successful video and it is really
teofiliuss
who has done it.
Look at the meter and the PC power supply in the background
of one of his videos.
I made 3 screenshots.
Here they are.
So you can see, that it is really
Youtube user teofiliuss
who has achived the great power output now
as user:
Regards, Stefan.
Omnibus
@All,
Here is a translation of a post by @Access in the forum http://matrix.3nx.ru/viewtopic.php?t=3. You can see the figures from the link. It would be curious if that's what Kapanadze's and Smith's devices really do -- "steal" energy from existing power lines (recall we had in this forum an Australian "self-sustaining" motor running on the energy of a local radio station). One way to exclude that is to enclose them in a Faraday cage if grounding can be avoided:
----Beginning of translation:
Kapanadze has managed to use the energy of the existing 50Hz lines for electrical energy transfer (LET). Having good grounding (grounding has to be at right angle with respect to LET) at a significant distance from the LET and a long iron conductor, hung on supports along LET at a distance of several meters from the base of the LET, attached to the resonance circuit, tuned at 50Hz, we obtain a simple "robber". Its functioning is similar to a receiver of direct amplification, let alone the method is efficient enough under high-voltage line (HL) 110-220kV (high voltage class HL) even for a low efficiency coefficient, sufficient for small country home (without any energy saving technologies -- cf. Fig.1).
Kapanadze has made something similar to the supergenerative (or regenerative, or heterodyne) receiver, introducing a generator which takes energy from one and the same circuit (or from the additional circuit). Voltage is being rectified and goes to the generator-heterodyne. It probably works on the second-third harmonic of the mains voltage (100Hz or 150Hz). Part of that voltage is transferred back to the circuit, increasing its quality factor, thus leading to increasing voltage. Someone, using the handle @granulum has shown in earlier posts an almost ready construction of that heterodyne principle and is the closest to uncovering the "Kapanadze conundrum". His construction is similar to that of some Brovin who has shown how to use the energy of an isolated capacitance (a sphere) for the increase of efficiency coefficient of the system.
Fig2. (with comments therein) shows additions by @Access of the described heterodyne principle.
Fig.3 shows receiver of electrical energy created by his (@Access') Ukrainian colleagues. In Fig. 3 a metal tube of 7-8cm diameter is filled with annealed wire, sharpened at the point of attachment to the transformer TP1. Capacitors with a coil wound on the tube form the resonance circuit. It has to be tuned to the mains frequency (50Hz). A laboratory autotransformer ЛATP2 is placed alongside the grounding. It is also used to tune the input circuit. Capacitors are for no less than 15kV. ЛАТР's should be for no less than 6A. ЛАТР1 is used for tuning the intermediate circuit and mainly for regulating the voltage in the load (with its help the outgoing voltage of 220V is obtained). The schematic presented is used in Ukraine. It's placed in the clearing alongside the LET of 500kV (in a forest area).
hartiberlin
Hi Omnibus,
the teofiliuss circuit does not use any ground !
Have a look at this picture:
http://forumimage.ru/show/1144282
Here you see, what Impedance matching means !
The one loop wire with the teslacoil is a transformer,
which transforms the high voltage low current into
high current lower voltage usable for the 2 bulbs !
Regards, Stefan.
