itsu
QuoteItsu, can your scope multiply Ch1 by Ch2 ?
...better yet, can it average out the result of this multiplication: Avg(Ch1 * Ch2) ?
@ verpies,  thanks.
My scope only shows the multiply ch1*ch2 as a graph,  no figures.
When i did that, it was out of view mostly, and adjusting the ch1 / ch2 setting only improved it a little.
I will change the CH1 / CH2 setting to "mean" to see if the ch1*ch2 improves further and show a screenshot.
My guesstimate is that it consumes about 12 Watt now.
Also i will use a low pass filter in trying to use my multimeter's as not everybody has a scope.
(and use better quality leads instead of the crappy crocodile clips i now use :-)  )
Regards Itsu
a.king21
Apologies if anyone has posted this info before, but here is DELAMORTO's site.
http://www.freeenergylt.narod2.ru/delamorto/
He seems on the level.
verpies
Quote from: itsu on December 12, 2011, 04:22:45 AM
DANGER Mr.Robinson DANGER:
Mean(Ch1) * Mean(Ch2)  <>  Mean(Ch1 * Ch2)
semenihin-77
10000mf cool and the LED pulse discharges, probably will blink a couple of days!
All it's time to sell via e-buy my Kacher, and collect CE LED! ;D
verpies
Maybe you scope is a little dumb and multiplies the vertical offsets of Ch1 and Ch2.
I write "dumb" because the vertical offset on the scope's screen is not the same as DC offset of the signal.
The former is a graphical property of the scopes's display and the latter is the property of the measured signal.
If so, then zeroing-out of vertical offsets will get rid of their artifacts, producing a clean Ch1 * Ch2 oscillogram.
We do not want to multiply the artificial vertical offsets of the scope but we do want to multiply the real DC offsets of the signals.
Anyway, even a graph of Ch1 * Ch2 says more about the input power than measuring it with a voltmeter and an ammeter, because Mean(Voltage) * Mean (Current) does not equal Power, but Mean(Voltage*Current) does.
If your scope cannot do Mean(Ch1 * Ch2) then the raw graph of Ch1 * Ch2 still can be averaged out with a manual graphical method.
I will gladly do it if you post high resolution scopeshot of Ch1 * Ch2 (with scope's vertical offsets well zeroed out)
