zhak
FreeEnergyInfo
it already was,
not for long
эÑ,о уже было,
эÑ,о не надолго
http://www.youtube.com/watch?v=IzDDiUF9mf4
http://www.youtube.com/watch?v=Rm3LPMQ-xdU
verpies
Quote from: semenihin-77 on December 12, 2011, 06:02:53 AM
10000mf cool and the LED pulse discharges, probably will blink a couple of days!
All it's time to sell via e-buy my Kacher, and collect CE LED! ;D
If we knew the initial voltage on the capacitor and the duty cycle of the LED pulses than we could even estimate how long it will blink with this 10mF capacitor.
...but as usual we have no In/Out power or energy measurements.
ronotte
@xenomorphlabs
sorry for delay in answering, I try now to update the group on my replication.
First to answer your question I am using for measurements my Tektronics 2232 100MHz analog/digital scope so the waveform on lamp load is measured like in the picture DSC_0964 where it is possible to see the probe in parallel to lamp (230V/60W). In that condition the current from the 24Vbattery is .8A so a total of 24*0.8=19.2W. Clearly the output power is not measurable but I am going to rectify the output itself and then measure the relative DC power.
The device after some optimization seems to work as expected, certanly the open end (Tesla coil ) shows some streamers and nearing a screwdriver I have 4mm sparks. I used a cheap (ft=2MHz) TIP23 power transistor with a 2K between collector and base...oscillations start easy after moving properly the slotted Cu tube. Frequency of the sinusoidal wave on load is 1.66MHz as in pic DSC_961 where T=0.6usec and V=200V.
I am going now to test different coils arrangements...
Roberto
itsu
Hi verpies,
yes i have battled with this before, and know that:
Mean(Ch1) * Mean(Ch2)  <>  Mean(Ch1 * Ch2)
But my scope can not do:  Mean(Ch1 * Ch2), so i can only use (Ch1 * Ch2) with the channels set to either MEAN, P2P or RMS
and see the resulting graph.
I don't think it multiplies the vertical offsets of Ch1 and Ch2 as i did zero-out the vertical offsets yesterday with no change (still out of view).
Anyway, i will see what i can do tonight and post a clear scopeshot.
Regards Itsu
jbignes5
Quote from: bolt on December 11, 2011, 10:09:01 PM
There was no "one way modes" or ball lightning, earthing "shorts"  or other catastrophic effects it was a very simple case of his earth wire which is INTENDED to be earthed  for proper operation had a number of cuts and twists in it from experiments and one join started to come apart  which burned up and caught the sheath plastic on fire.  No big deal he noticed it and problem solved.  So i don't think cages are required for normal operation.
You should know at this node point is VERY high amps but very low voltage perhaps dozens of amps.  As Kapandze green box video his earth on water pipe also kept over heating.  These little events are normal during rushed experimenters set-ups and demo's.
I do believe he was carrying the ground in his hand and the wire on the other end was a virtual ground. You can clearly see one wire going to both lights from the metal shield. The other end of the lights went to the virtual ground<Not connected to ground. When he did connect it via an earth ground it went ballistic and got very bright. So now all we need to do is pulse that virtual ground and walla. Controlled reaction!
At some point after doing the experiment many times, he drops the ground and it attaches to the virtual ground line that he had hanging near the ground down near the floor. It didn't come apart it shorted and it is very clear what happened. Try pausing the video and go frame by frame. Instead of guessing why not watch the frames.
The danger is clear. Things to keep in mind would be built in safeties to make it a wonderful discovery and not a dangerous one. The dangers are clear and we must state that you were warned. Free energy comes at a price. It's got to be used for real freedom and all of life's rights to peaceably live and love life . Defense is the first objective. Learn how to protect and defend. Humanity must prevail and grow out of our slavery and ill gotten gains. Are you not tired of all this survival mode they keep us in? Things are gonna change but heck what a change it is gonna be.
Hopefully we have amassed enough wisdom to survive this. Other technologies are on the move and I like what I am seeing! If we don't do this and take the burden off our peoples back, we will break Humanities ability to become and do Good for all life in this Universe! We have the information now it's time to figure this out.
Stay safe and practice good scientific safety. Please..
