0 Members and 185 Guests are viewing this topic.
jbignes5
Quote from: znel on December 12, 2011, 08:10:55 PM
I considered that one a success along the long road of learning.   It would run small DC motors, lamps and lots of LED's and ran with an input of 4.5 volts and 50ma.    It's along with many many others in my notebook.    The tubes were slit to reduce eddy currents, strictly air core.
I'm not sure what you mean by bands instead of a slit copper tube - seems like the same thing to me - unless your talking about a helical ribbon which would make sense to reduce eddy currents even more and put it on an angle that might intercept the magnetic field in the core, forming a single turn coil.    That actually sounds like something I should give some examination to...
Sometimes words don't form the same picture from one to another, I have a difficult time with word pictures - if I can see it in my mind clearly, I can build it...
yes just one complete turn around the ferrite on an angle. One of those should make it like pumping the strip of copper with the field going into the Ferrite.
vrand
Quote from: woopy on December 12, 2011, 06:31:24 PM
Hi jimboot
i tried first the experiment with the bulb of my first testing where i got only plasma flash as per my previous video.http://www.youtube.com/watch?v=6ocPYYEv37g&list=UUi3fFZN1pwHTyM8H_nSxerg&feature=plcp
And with the Delamorto arrangement this same bulb's filament  glows as per normal electricity.
And i changed the bulb only for sake of  simplicity as i got a better bulb adaptor
No doubt Jim , the delamorto works very well
and last update     i disconnected the second wire of the bulb from the negative lead of the input and connected it to an antenna (around 10 meters of wire outside of my shop and it works too. than i connected the antenna to the negative and it was always better.  ouuchh  :o :o :o
That is to say that we are working in open circuitery   and the " don't kill the dipole " rule and it works   youpla!! ;)
let's replicate
and good night at all
Laurent
Hi Laurent, thanks for sharing the Kacker delamorto experiment and with the caduceus coil twist. :)
Did you already try out the original delamorto experiment?  Test results?
Cheers Mike
Jimboot
What am I missing here?
I just tried sitting a Rodin coil on top of my coil attached to the split copper pipe and then to the lamp and the other side of the lamp attached to the ground. The lamp lit. I then removed the copper pipe and with just the rodin coil the lamp still lit. I then remove the rodin coil and attached a variety of objects , lead sinker, screwdriver, brass hose fitting, heatsink and dropped them all into the centre of my primary coil. The lamp still lit.
Variables.
The rodin coil was on top of the primary not wrapped around it.
I did not have an amp meter attached.
My copper pipe was not a snug fit - coil dia 50mm pipe 19mm
The lamp itself is important. I have tried lower wattage lamps and they have not lit. Only the 240v 25w lamp from a set of festoon party lights brand was Osram.
I still get better lighting from attaching the lamp directly to the primary with a loose aerial attached to the other side of the lamp.
From my exp the sem77 device seems to be an aerial. I'll have a vid up soon. I'd love woopy to hook up the lamp he used in the copper pipe device directly to the primary if you have not already done so. Or see if you can light the lamps that only gave plasma light up with the copper pipe device.
Hope
Quote from: jbignes5 on December 11, 2011, 03:00:06 PM
Ok I had a chance to reread the bankruptcy notes from the court hearing. There is a section in this book that starts on page 64. http://books.google.com/books?id=KRg9HWakBmQC&pg=PA64&lpg=PA64&dq=tesla+gave+westinghouse+new+soft+iron+for+transformers&source=bl&ots=0SjD0CgTBB&sig=oZ-dIBnH9jnWaT_688Dtm0YWvso&hl=en&ei=upTTTszED6Xf0QGl3qxL&sa=X&oi=book_result&ct=result&resnum=4&sqi=2&ved=0CFQQ6AEwAw#v=onepage&q=tesla%20gave%20westinghouse%20new%20soft%20iron%20for%20transformers&f=false
The description of the device is exactly what the Exciter(alternator), Transformers*4((4 coils hooked in two pairs in series)4 Field coils around generator, two pairs in series). It seems in this configuration with commutating breaks right at the peeks of each transformer. This gave him a solid dc voltage to charge the caps to 44k volts! Ouch now thats a blaster!
This link is great stuff,  thanks Big!   I never knew these records were around.   AND, yes it does look like this is a similar circuit.   Do you have anything on what Tesla does to tune his devices??
Jimboot
Ok amps measured on 12v. On the aerial device 400mA. Connected directly to the primary 950mA uploading a few vids now.
