0 Members and 45 Guests are viewing this topic.
Hope
Quote from: jbignes5 on December 11, 2011, 07:47:08 PM
I started to think more about the one turn copper plate bent around the ferrite rod. If you hooked a wire to the upper left of the plate and the lower right of the plate you would get such a huge current rise that one side would be very high in current and the other would act like the ground. You should be able to run a very good amount of current that way because of the swirling flow of magnetic lines going into the copper towards the ferrite. Hmm is that the key?
Nice observance Big,  so perhaps we can use this to harvest the compressed field.  Imagine holding that compressed field in a magnetic path like the arc magnets do.  Then tap tap tap until we get the field spinning to a ultra high spin, similar to that yoke Youtube where the guy increases the C battery voltage from 1.5 volts to 400volts using only a "C" battery a yoke ferrite and a few neo magnets and copper wire.
Jimboot
Here are my vids.
Kacher/slayer with delamorto pipe and aerial effect.
http://www.youtube.com/watch?v=0M1i9kZB8qI&feature=channel_video_title
Amp draw readings from the lamp connected directlt to the base of the kacher slayer
http://www.youtube.com/watch?v=ke0YU7vHNNM&feature=channel_video_title
Amp draw readings of the rodin coil aerial on the kacher
http://www.youtube.com/watch?v=qUtmIogFunQ&feature=channel_video_title
ramset
An Auction Question
'Can I heat My tea with it'?
I like My tea made  "Just So""
Its important for me to Know How much power I use [the killowatt meter]
And how Hot the water gets ??
Can you do this twice
First get my tea container put one liter of water in check the Temp??
Second plug the light bulb in to a regular fixture and the Killowatt meter just like the pic below.
Heat one liter of water until the meter goes "one click"
How much time ??? Whats the Temp??
Now do the same thing with your Catcher device
Does it Catch any Xtra??
If so Your Bid will go thru The roof......................................
Thank you
Chet
Thanks Grandma
jbignes5
@all. Very soon I will be joining you guys at trying to figure this stuff out. My experiments have not been started yet due to my frail health. But I am feeling much better now and I will be doing these experiments with you guys. Also my experiments with crystal batteries is just about completing the last of my ideas.
I got way to many things going lol... My research which I have been doing for 10's of years now has allotted me to amass quite the databank in my head. Although I am finding it tough to remember exact details, I don't seem to have this issue with general ideas he presented. I have read So much about Tesla. Both official and unofficial. If anyone says he didn't use numbers and math to do general things in this have never really read something he wrote. He did use math. He also knew surfaces and geometry very very well. If one applies the static world and it's laws to our world it explains everything in the universe. Static laws transcend Millions of miles. This is how galaxies form and the solar systems ebbs and flows. Gravity is totally explainable when you understand the mass of this world. There is a flow. Surfaces(Alter that flow) and charges(heat, it binds it together,static portion).
In fact Induction is that static portion. What did we learn about it? NOTHING. We threw it away...
It was merely a toy. But it was the secret of it all. When combined in the right way it is always present. Eternal. It is the part of electricity that gives it a possibility to have direction and alignment or order. It is the reason we are discussing this here. If the static portion was totally denied how could we truly understand it's relationship.
Tesla found out that anyone, anywhere could create their own surface to harvest. The vortex is that surface. The funniest thing is this surface attracts magnetic lines. Once the lines are established all you would need to do is hold them. Why not hold them with an inductive barrier. A self filling electric bottle that can be squeezed.
Look, take this setup and multiply it by 4. Join each ferrite into a circle. Hmmm... Isn't that the stevep device? We are just using 1/4 of the real Tesla device. It can never have a built up momentum. We need the circle of ferrite or iron. My bet is on Iron. I have a 10" split ring soft iron bar waiting to go. I got to get some Good copper for the unit. The exciter I have 4 24 pound pull neo's in ring fashion. Flat doughnut style. I figure I'll pair them up. I need the rotor/shaft section still and bearings. I have an induction motor recently made but I am thinking these need to be special motors and custom made. Tesla was very specific about that. Oh and I'll need to make an aluminum housing for this. It's gonna need a good heatsink. I guess the premise is that you only need to charge this field up and it will go for quite some time before coming to rest.
My proof for the long time comes from Leedskalnins work. I hope I spelled that right. I think he had the mechanics right but it wasn't magnetic current, it was the Eletrostatic current. It has the same rules. His charging a coil around separated iron pathway was brilliant to say the least. He understood what Tesla knew. He was a book worm. But to get back to the point once you pump up the iron with lines all one needs is to impress a pattern in the pathway and set it in motion. How you extract the energy should be in a bifilar way. That way it does not effect the spin except for a very small amount, the resistance of the wire itself with no self induction. Coat that wire in Silver and man We might have a winner here.
Our experiments are showing promise on a small scale. Lets multiply this and see if we can control this in a way that will rev this up and produce more current. Remember Wave guides and fluid flows when dealing with this stuff.
