0 Members and 319 Guests are viewing this topic.
znel
Quote from: baroutologos on December 16, 2011, 03:27:55 PM
My lately build Kachers all are operating normally on their bulk LC resonance.
But, in this case http://www.youtube.com/watch?v=Jxp6wrh2Pqo (after enforcing a voltage node on toplead) it seems to operate at a frequency dictated by L/2 wavelength. Of course this changes by ferrite addition, but it does not seem as a harmonic of LC either since especially the C component can be altered without frequency alteration.
I am interested in exploring this view. Can you demonstrate the principle?
I tend to jump from one project to another based on various discoveries along the way and other than my notes I neglect taking the time to document them on video.   My time is limited and I spend most of my spare moments building the next project looking for the missing pieces - to many missing pieces.   Unfortunately, there are more failures than successes but that makes the few successes that much sweeter I suppose.
The best way to explain it is to tie the coil with everything your going to do with it, then check the spectrum for the highest peak at the lowest frequency.   I found if you simply make a coil and keep adding things to it, it changes all the variables and it's like finding a needle in a haystack.    I use earth ground on most of my experiments so I connect it to earth while looking for the peak.    A bulb, wire clip, long wires, top load what ever, will change the variables to make it perform differently.    I'm looking for the interaction between the coil and environment specifically - whether I'll find all the answers or not only time will tell....
grizli
I was away for almost a month ?
Any STAARS team device replications so far?
any 50hz that does not kill the source replication ?
Any third party OU devices replicated
Please respond to me in short notes... hard to read 80 pages I didnt follow ..
verpies
Quote from: grizli on December 16, 2011, 05:11:21 PM
A lot has happened but not many good things.
The STAAAR team abandoned the Yoke device after they discovered that it gets permanently magnetized and its frequency starts exceeding the capability of their frequency generators.  Nobody besides Arunas and Wesley was able to tune the yoke device (they made a video of it though).
Wesley (stivep) attempted to post clear tuning instructions but they were far from coherent.  I attempted to clarify these instructions but nobody from the STAAAR has ever cared to clear up the issues I marked in red & blue color in the post below:
Quote from: verpies on December 06, 2011, 09:09:14 AM
Below are my interpretations and rephrasings of the tuning instructions pertaining to a device using  ferrimagnetic core from a TV deflection Yoke.
Wesley had gone to Lithuania where he worked with the others on another device (the SAAAR Tube device) which was unremarkable except for one trumpet shape oscillogram, because no valid In/Out power measurements were made, as usual. There was one nonsensical input power estimate on the basis of power consumption comparison of a shunt-type power supply between load and no-load conditions.
For over a week Wesley has been silent and the attention of this thread has shifted to a similar Tube device called the Kacher.
It differs from the SAAAR Tube device somewhat (e.g. simpler and no caduceus coil) and does not exhibit that interesting trumpet oscillogram.
Gross I/O power estimates do not indicate that Kacher is OU, either.
Both of the tube devices output high voltage, high frequency waves that are difficult to work with and hard to measure by anything more than a light bulb.  Nobody has attempted to scientifically quantify the bulb's brightness and correlate it with equivalent DC power dissipation.  Eyeballing is the norm so far.
Both of the tube devices seem to be effective distractions from the Yoke device.
