0 Members and 123 Guests are viewing this topic.
jbignes5
Quote from: znel on December 16, 2011, 04:05:54 PM
I tend to jump from one project to another based on various discoveries along the way and other than my notes I neglect taking the time to document them on video.   My time is limited and I spend most of my spare moments building the next project looking for the missing pieces - to many missing pieces.   Unfortunately, there are more failures than successes but that makes the few successes that much sweeter I suppose.
The best way to explain it is to tie the coil with everything your going to do with it, then check the spectrum for the highest peak at the lowest frequency.   I found if you simply make a coil and keep adding things to it, it changes all the variables and it's like finding a needle in a haystack.    I use earth ground on most of my experiments so I connect it to earth while looking for the peak.    A bulb, wire clip, long wires, top load what ever, will change the variables to make it perform differently.    I'm looking for the interaction between the coil and environment specifically - whether I'll find all the answers or not only time will tell....
That method will not work. Tesla clearly states in the court papers that the higher the frequency the better the output. You are thinking in reverse here and this is what always gets us going back down the same road here. Yes having clip leads and long wires without shielding will always be a loss in a radiative system. Come on guys we need to bottle this stuff up and pressurize it. We are not seeing the same results because it is all gone before we try to use it. Shielding, shielding, shielding, is the only way to do this stuff. It is electrical in nature and not current driven. Do not think of a ground shielding since that is the way we setup this flow. The only other choice is static shielding around anything capacitive discharged or after that point. This stuff is very fluidic remember that. Seal the leaks inductively and this will power up most of these devices.
I can't speak for Stevep's device since that has a major flaw with the ferrite locking into magnet mode. Replacing it with iron should fix that issue.
znel
Well, I have to go with my gut on this one from what I've seen and how it responds.   I have to question the term "high frequency" as well, what did he consider high frequency back then.   He spent alot of time making very high inductance very large diameter coils which would indicate he was using frequencies in the range of 30-100 khz.   Our coils are tiny in comparison.
If he was truly working with some harmonic of the environmental frequency to pump the earth I wouldn't think that the frequency would need to be all that extreme.  You also have to consider his math as the primary tool used to determine frequencies of coils which I've found doesn't always coincide with what the coil is doing when measured on the scope.  Overall we don't know what he was doing we can only speculate.
So far all we've seen are stories, nothing real - no real replications... that's why we are here learning from the failures of others.   I wonder how many replicated the initial event that set tesla on this path... I did... quite honestly it scared the krap out of me.   It's time to do what others are not....
baroutologos
Hello Verpie,
do not be over worried about any yoke device or whatever. In my 2-3 years in this forum, the attention of this thread as well others has been swifted to numerous devices and concepts. Yoke has nothing special according my view. It was based on a nice concept - that with a NMR responce of some kind - ferrite can be stimulated by energy E1 in terms of magnetisation and output E2 in the same terms which is to be harvested by a third coil. Hence OU.
In practice, it seems this is not the case. Never run it to 1 Kw scale with same equipment, never were made accurate power measurments etc etc. To me, the yoke device was a "political pressure tool" towards Kapanadze so as to suggest him its time to let it go. Kapanadze on the other hand, if not a charlatan (this is a great chance also not to be neglected) stubbornly refuses to say anything of value, and dreams piles of money that will never come of course...
So... we proceed. Restless spirits cannot be confined to a yoke concept right? :P
ronotte
@znel,
I concord with you, after many tries of the Kacher-tube device. even if I succeeded like many others to have almost 300V on 60W/230V lamp load, my feeling is that it is a pure electrostatic device hence impossible to cleverly utilize its output on anything different load from a lamp: but you cant run wires in your home to light lamps at 1.6MHz :-[ and anyway I do not see OU or any trumpet like waveform clearly signalling a possible OU condition.
Any effort I did to lower the tube resonance frequency failed except inserting a ferrite rod...but then efficiency dramatically decreases and Kacher stop working. What we need to do is scale everything down to natural KHz range or lower ... better some harmonic of earth resonance...Tesla teaching...I think that even going with only a  1meter diameter coil should lead us to completely different effects.
Roberto
