0 Members and 160 Guests are viewing this topic.
T-1000
Quote from: Jimboot on December 16, 2011, 05:25:25 AM
I can get a lamp to light with the delamorto device but I still don't believe I'm seeing anything else than an aerial effect. Anyway the ferrites do have an effect as you would expect but I think the type of lamp is more important. Here's my latest vid - I'm still not keen to hook my USB scope up to this beast. http://www.youtube.com/watch?v=Z6T8vutgPHY
Hi,
You need Tesla step down transformer for this. The coil should be same as exciter's (kacher in Russian), just windings into opposite direction. You should get wireless energy transfer if you place that secondary coil nearby.
Good luck!
Quote from: verpies on December 16, 2011, 07:14:37 PM
Arunas,
What is MIRW ?
It's nickname of author in http://cyberenergy.ru/member/MIRW/ :)
About Yoke device - we did not abandon it. Until we find what is going on in ferrite core (you know, it cannot become permanent magnet in "normal" conventional usage) there is no stable result to show for everyone. Demagnetization weakens effect each time if you wonder for easy fix.. :)
P.S> Delamorto experiments have similar working principles behind ours and it is much more safe way to start with OU devices for those who are not experienced with frequency and high voltages.
stivep
Quote from: verpies on December 17, 2011, 05:33:20 AM
QuoteYes, accurate power measurements were never made, which is frustrating in itself considering the fancy test equipment that Wesley had at his disposition.
well I did not have that equipment in Lithuania experiment.
QuoteEven without sophisticated equipment, more accuracy than eyeballing the brightness was possible with a light bulb and a photodiode in a paint can.
There was no photo diode in  Lithuania Experiment.
QuoteIn my opinion the Yoke device was special because:
1) On the input side, the 10W power limit established by those two PCGU1000 signal generators was pretty convincing.
2) On the output side, the eyeballing of the bulb's brightness was unscientific and unquantifiable but seemed to exceed 10W significantly.
3) The oscillogram of the HF riding on top of the ~50Hz 140Vp-p waveform, was very unusual (see the attachment)
no comments self-explanatory.
I
Quoten comparison the SAAAR Tube device (Lithuania experiment) had:
1) Nonsensical input power estimate based on the difference of power supply's power consumption with load vs. no-load. See: Reply #9256
2) On the output side, the practice of eyeballing of the bulb's brightness was as bad as with the Yoke device but seemed to not exceed 30W-40W on a 100W bulb (80% 98% of the input power)
3) The trumpet shaped oscillogram was very unusual (see attachment)
everyone has  his own perception and opinion But not everyone wants to spend $3k to see it it is true.
QuoteBecause of the above, the SAAAR Tube device gets a point only for pt.3 and the STAAAR Yoke device gets points for pt.1 and pt.3 and maybe half a point for pt.2.
Thus in my opinion the score is at least 2 : 1 for the Yoke device, and on that basis I consider it "more special" than the Tube device.
Good point. this is your judgement  so let it be.
QuoteAlso I noticed that after his trip to Lithuania Wesley was not the same man - not as forthcoming, preoccupied with non-technical issues (e.g. disclaimers) and posting less frequently on this forum, his replies were wandering (not to the point) if there were any.
Maybe he got replaced by a reptilian ? ;)
I agree I'm not the same man.
QuoteYou can't be blamed for moving on, but it is different for the STAAAR team because they did not finish what they started.
The permanent magnetization of the core could be eliminated by driving the Yoke device with symmetrical AC waveforms and other well known techniques.
Yes Wesley lost additionally   $700 because of Chinese junk product transformer marked as 110V to 220V that was 220V to 220V
His American made Wavetek  generator got  permanently damaged.So never trust Chinese product.
At the result Team was left with
one   generator 2MHz
one damaged previously  generator 2 MHz
one replacement generator exactly like one that was damaged that I have brought with me to Lithuania.
Two experiment  have been provided
1 ferrite yoke
2 caduceus tube
Statue of limitation when team has been using degaussing coil to return ferrite to its original resonance  properties. Instead we could of try to tune device with new resonance power 2 MHz but we did not have  sufficient generators.
- the man the best in tuning  was in England remotely controlling generators.Arunas could not come to  Lithuania with me.
QuoteThe 2Mhz frequency limit is a non-issue even for the Chinese signal generator that Itsu was using.
I would even pay the STAAAR team for two 5MHz signal generators, if they got their act together.
Well it was an issue at time of experiment. and statue of limitation as well.
Right now  we try to recover and get back to experiment.
Aidas needs  new set of generators  ( good one)and I'm working on it now
Aidas need new bipolar  power supply -generator
We all got stuck for period of 2 weeks with videos and responding to you-tube comments,private comments, emails ,skype and forums.
That was so intense that no time for any experiments was left to us.It was not even time to sleep or rest.
with that demands and pressure from people like verpies as well.
Conclusion;
1. you Sir can bit the bushes the result will  be NO RESULT. There is no more info that can be given
2.2 the statement is two devices works as  stated !!
3.no explanation so far come from TK even if he said  that He is giving it to the people..And nobody complains about it.
4.I'm the only one who till now spend  over $10k just for trips to TK and Lithuania.Just to give it to the people at the end of it.with no personal benefit other than just being able to see TK by myself.
5. I might be the one  or one from few who decided to invest  in lab to this extend and I spend even more because I know what I have seen.
- 1.5 years ago  150W driven from 2.75W stupidity of mine was  to fallow advice of friend scientist that If I did it once I will do it again and I can not do experiments with  twisted wires and chaos in my bench. I should not touch it.But that was a trigger point to invest in the lab.
-TK 200W device presented to me  working from single impulse for 30 minutes.
- Lithiania Experiment
a. strange field from yoke that I opposed to be at X-ray origin  or any radiation. BUT I have got pain in right side of my head that felt like partially skin  affected by temperature   extending deeper to brain. if we take  impedance mismatch
than we have had  delivery  of effective mili-watts to the yoke  not  stated  5 Watts per generator.
Strength of the field was tremendous.By all of logic this should of never be present.. The pain vanished 4 days after me returned to US
6. I'm not a  wealthy man I'm constantly investing ads much as I can to DELIVER
7.I will not any longer spend 16 hours a day just to respond to questions and comments or fight with anyone.
8.All I have is my wife and my lab that makes me happy rest of it is just simple life necessities.
9. I do not drink , no entertainment  , no TV, no restaurants, no fun of any typical nature, no society life and no waste of my time on BS. I woke up and start my science with the coup of coffe, That is how it goes.,
"TK"technology  is my biggest and only sacrifice that consumes all of my resources.
So  Verpies do what you want to do  and put all of the dirt on me . It is not going to change anything at all.
You will be standing exactly where you are. No motion will be increased  that would be of any benefit to you Sir.
If there is no motion than there is no need of notion as a trigger point.
All you going to achieve that I might be less and less on this forum. But I will proceed forward  to the goal I have in mind but without your assistance Sir.
Wesley
jbignes5
Quote from: znel on December 16, 2011, 11:19:12 PM
Well, I have to go with my gut on this one from what I've seen and how it responds.   I have to question the term "high frequency" as well, what did he consider high frequency back then.   He spent alot of time making very high inductance very large diameter coils which would indicate he was using frequencies in the range of 30-100 khz.   Our coils are tiny in comparison.
If he was truly working with some harmonic of the environmental frequency to pump the earth I wouldn't think that the frequency would need to be all that extreme.  You also have to consider his math as the primary tool used to determine frequencies of coils which I've found doesn't always coincide with what the coil is doing when measured on the scope.  Overall we don't know what he was doing we can only speculate.
So far all we've seen are stories, nothing real - no real replications... that's why we are here learning from the failures of others.   I wonder how many replicated the initial event that set tesla on this path... I did... quite honestly it scared the krap out of me.   It's time to do what others are not....
I hear Tesla speaking in terms of 1 million pulses+ a second, in actuality Tesla had a hard time measuring the true frequency of pulses. He did know it was way faster then what he could establish via mechanical means. But then he wasn't using RF frequencies. This was a new type of wave. Only half of it was supplied. The other half was of the environment. Think of it as this. We live in a very dense energy field. This field is the planet we live on. It radiates everything we need.
This network can and will respond to subtle energies like high voltage. This forms a network of energy from central potential to outer space and beyond. Mater is what guides this network.It can channel it and squeeze it and even reject it to a degree. All matter in the universe is connected via this network of energy conduits. It has density and this is what Universes are about. It's very dense and flows like water and is in fact the reason water exhibits it's miraculous properties.
Since this network can work on the subtle vibrations, as Tesla found out that it would respond back with all the force of the Universe. The Universal pressure(mater) or Anti pressure (Vacuum). Figuring out how to link to that pressure was the trick. Induction had it's caveats and Tesla learned very quickly how to get mater to respond to that natural flow path twords the center potential. It was lined up exactly how he used magnets to quench the gap. Through the magnetic path it will not effect the discharge except for current which it wicks away. I believe it is a filter really.
I'm starting to think that is our problem in recreating these effects. It needs to be pure potential and any current would be very dangerous to the coil and anything after the coil. Any deviation from prefect clipping and it causes damage to the feedback signal or device. I think when Tesla got the devices into resonance they had perfect transformation of energy from one form to the other. Then he used both sides of the signal to power his devices after transforming it down with any energy that was sucked into the antenna from the environment.
Any air Could be striped of it's energy and turned into ozone in the process with the antenna version. Ozone must be very light because it is very high up on our atmosphere. The ozone would fly up and recharge to become Atmosphere again and rejoin the process. This will also help repair our ozone shield as well very quickly. In fact we might make it so it is better of a shield.
skaarj
Hello Mr. Wesley
Now I understand why you cannot answer PMs.
Questions (for you and other people in touch with soviet technology):
1. have you ever tried to protect your signal generators using a buffer made of a few field-effect transistors? or better - vacuum-tube based buffers?
2. Are you guys familiar with KBH-49, Temp-2, Rubin-A and Rubin-102? did you try to use such cores?
3. Deflection cores from high-resolution, high-scan-frequency big video monitors (example: 1600x1200@120Hz or more). These cores are designed to work with frequencies higher than 15625Hz. This is the core I will use when the equipments will arrive. Any recommendations? (others than reading all the topic from the first post of you, Mr. Wesley, which I am doing for days and nights until my head explodes)
I am following your steps for replicating the yoke device, Including the US$3k for equipments you mentioned on all your videos.  Made myself a script to download all youtube channels (of you and related to your work) as fast as possible before they manage to remove "interesting" films.
I repeat again what I already sent in a PM: I will not associate any of my failures with you or your team. Just want to replicate your experiment and in case of success, to explain this in more clear scientific terms so it can be replicated by anyone. You said you want someone smarter than you. I hope to make your wish become true.
Now - I noticed you guys are playing with ring-shaped ferrite cores. All cores have an attribute called "hysteresis" - this means they have some king of a magnetic memory. If ferrite stays in a magnetic field, it remains (more or less) partially magnetized. "More partially" magnetized is translated in scientific terms as "big hysteresis cycle surface" and means a weak magnet. "less partially" magnetized - "small hysteresis cycle surface", meaning an extremely weak magnet.
Now - materials with big/huge hysteresis are used in chokes for filtering current spikes in computer power supplies and many other devices. You build PI-filters with them. YOU DO NOT BUILD TRANSFORMERS with them because they will not work, they will lose energy for changing the polarity of that strong magnetic residue, which again remains in the core with the reversed polarity.
Cores with extremely small hysteresis cycle are used in transformers. They can also be used in filters but with low gain.  There's no remaining magnetic field inside the core when pulsing the coils (continuously or alternate), so there's no energy lost for polarity reverse of any remaining magnetic field. That is the kind of a core you should use in all yoke-based experiments. Low hysteresis cycle. And as old as possible. I believe these new cores are limited to a specific frequency range, just to stop us from experimenting.
I  believe I read around 150 pages of posts on this topic but I do not remember anyone to talk about this.
semenihin-77
I express gratitude to Wesley! His dedication can only envy. Having the opportunity to go to Georgia and see personally what many only seek - it is an achievement.
The main thing is not to stop! Sooner or later will reveal, do not despair! Wesley, Delamorto with you!
