0 Members and 41 Guests are viewing this topic.
jbignes5
http://www.rmcybernetics.com/science/physics/electromagnetism2_coils.htm
Check out the penning trap on the bottom.
This should help us to see the interior of the Tesla coils field. So I was right it acts like an inductive bottle. Learn how to increase that buldge in the middle and we got a game changer here. We can also variate the internal bottles shape via exterior coils that are self terminated. Inductive loops. If we unshort them they release the portion they influence letting a small bump in the field be created. Turn them on and off in a rhythmic fashion and we have an effective pump. It seems to me that we can vary the strength of the loops as well so that we can create a fluid like squeezing of the bottle. Trap then squeeze twords the copper 1 turn coil. Which should be heavily inductively shielded. A cascade amp setup should do for the worm like pulse of the control loops.
This should mean that the device on it's lowest setting would be the very least it needs to bias the channel on.
Could this be a parallel? http://www.youtube.com/watch?v=oY1eyLEo8_A&feature=related
Hmm Try this one: http://www.youtube.com/watch?v=P6_tOGo2I4k&feature=related
@ stevep, Listen buddy, Do what you are doing. Don't let anyone dissuade you from your goal. Stay and share with us. If they make demands tell them to make the experiment themselves. They can then demand all the answers they want because they ARE REPLICATING AND DOING IT. Its the whole point in reporting things. Forget the nay sayers and lets grind this out. Take your time and for pete's sake use precautions. I don't think Tesla was moving the field like you were without a counter movement. He was using the in and out of the electric field. Not the traditional magnetic movements. He used the surface to fluctuate end to end, center to outer. A rain drop in the pool of our planets. If we are moving at such a high rate of speed through this universe we must be plowing through the network as we speed along. creating your own surface seems to be the way to go in this.
What if we want to copy the solar systems way of operating. Create a big enough point of potential and you could change the way we feel gravity. It would change to the surface of the emitter. We could get an all inclusive support system for going into space. Including virtual gravity. Since all I think gravity is, is a flow twords a central point. Create a big enough flow and gravity appears.
Make our ships round and put the pump in the middle with special cables running to the outer surface of the sphere. Regulate the flow and walla as much power as one wants. The perfect cyclic system. A portable support system for the human condition. Dynamic inductive shielding will allow you to separate floors and allow flow control. You just want to polarize the space within the floors. Shielding will look grates with grid like connections. It will have to be big unfortunately but it would sustain life indefinitely if needed. Most animals can be cloned or near clone able. So animal propagation would be easy if need be. It could be ark like if you will. Both in species and in plant life. We already have a storehouse of all grains of the world. Maybe it is time to put it to good use.
We know there is ionic winds in outer space. If that is the case then this could be the clue to the patterns of our solar systems energy matrix. We know the sun spews a solar wind as well and that has to be the key to this solar system. There is a surface to this solar wind. The Sun has a vast output of energy. This energy it seems is planar in nature. It could be there is two halves to this planar nature. One on either side of the solar plane. Each spinning in the same direction. What is squished in between the two similar networks is our solar plane. The sun is merely a conduit of great energy that has sprung a leak. Mater is attracted to it like flies to poop. But the solar system is spinning and central fugal forces are at play too. So there is a delicate balance there and things orbit now. But I digress... Back to the research...
stivep
Thank all of you for your support I can not even  list all of the names to many of them in all channels and all media
You know your names:)
O boy...
I did not expect so much of public appreciation I do not even  think that I deserve it all.
Thank you Vladimir Utkin for all knowledge that you provide to all of us.
The reverse ringing wave form predicted by you we have seen at Lithuania Experiment.
The coil capacitor is your previous  idea and subject of your experimentation
The right hand magnetic field vector between plates of capacitor was conformed as existing factor influencing EMF at
L character -inductive coupling  interaction.
So far there is NO conflicts with your theory.
Wesley
znel
Quote from: Kator01 on December 17, 2011, 01:57:15 PM
Hi Znel,
No wonder that you had this frequnecy-phaenomenon
I know this Meyl-Setup. Actually I have build this "tranmitter" myself and tested it with a High-Frequnecy engineer.
Now all claims Meyl made about velocity beyond c are not true. His setup is a complex hf-bandfilter with two resonance-points because of stronger coupling ( 2.5) of the two tanks. Look at the light blue resonance-spectrum. Here you see the two resonace points.
It seems the Kacher itself shows some similar features of a bandfilter. This could be an endless story, so better have a controlled tesla-coil system like it is shown here in the link provided earlier by some user here in Volume 17 Isue 2, page 12-15:
http://www.teslauniverse.com/
kator
kator, I was the one that posted that link some time back....
Kator01
Quote from: znel on December 17, 2011, 06:13:53 PM
Hi Znel,
I could not remember because I read in so many postings in different topics,... anyway i am very greatful that you presented this. A big fundus of knowledge.
Kator
forest
Take a bell and a hammer , with unidirectional sharp impulses of perfect synchronicity with long period between you can have perfect undamped oscillations from just a few basic impulses . That's what Tesla device is : a bell and a hammer. Hammer decides of energy input and bell assembly desides about the vibration undamped or damped quickly. All this is known for you and proved by Stiveip and Znel experiments (when receiver is incandescend bulb). This alone is OU. Exactly like pointed by Znel. Few watts used to charge capacitor at correct moment and sustained vibration prolonged many times then initial discharge. What is missing is clever receiver system without affecting transmitter. That's all ! Vladimir Utkin is right and my ideas too....   ;D
