0 Members and 182 Guests are viewing this topic.
jbignes5
Quote from: Hope on December 25, 2011, 11:58:19 PM
Tesla's Radiant Energy - YouTube
After watching this clip a few times and reading it and a lot of thought (and a bit of Christmas dinner) :
I want to suggest a similar condition happens when hydrogen is burned.  The high rate of burn can be correlated as HF oscillations and would produce very short wave lengths.  This would account for the measured temperature of the hydrogen flame when reacting with different matter.  On matter like human skin the temperature is measured around 260 degrees F due to the wave lengthens passing between the sub atomic particles.  When the flame is heating a metal or more solid mass the temperature is measured much higher, such as ceramic brick 2000 degrees F and Tungsten at around 6000C
This may well be due to the wave length hitting the atomic mass instead of passing thru it.   This would mean there are wavelengths that are disorganized and COULD be made longitudinal and into (as James C. Maxwell math predicted) gravitational focused waves.  This would make sense about these Joe cells losing gravity.   I think this needs investigation.   Thoughts?? anyone.
This would also lend an explanation to how AF E-Cat cold fusion reactor is bumping neutrons to decay nickel into copper and harvesting the then lose electrons.
ALSO most importantly as concerned an this topic, during the spark gap the plasma is burning the atmospheric hydrogen causing a similar wave length.     Thoughts are requested on this subject please.
Ok So now think of the polarizing effect of two magnets in attraction mode across the gap. Now think about the polarization that two bucking fields like north north or south south. If you had two bucking fields but the shape was flat donut, that way you could insert the spark gap through the center hole. Maybe thats where we need the other part of the iron loop. Maybe center that 90 degrees out of plane like an equator. The coils would always present a restriction. Especially when shorted. We could just pulse the shorting and extract that flow with a bifilar wrap over the internal single layer coil. Shorting that internal single layer coil would restrict the flow be cause of the massive self inductance. The Bifilar pickup coil will receive the energy and the iron core will always be excited into field dynamics. You bias the iron on(saturate) and you can modulate with a very intense field how that energy flows. Learning how to get the system to intercept more flow (current) is the trick. It has to do with ratios and math unfortunately. Geometry, statics potentials and hydrodynamics (densities) is gonna be the main factors or rules. You could think of the Iron core as the conduit. It will always be higher in potential then anything near it. It is the focus and it concentrates it's power by constantly running at huge ranges. As mass gets bigger these potentials can be spread over vast distances of matter. And yes in some density space is matter as well, it is just spread out more. Pockets of condensed matter like gases and dust show that matter can retain itself in looser(spread out) energy networks. In essence it creates it own skin and mass by condensing.
Water is the best know results of this networks operation. All water is, is the condensate of the network itself. Proof is the vast water reservoir ever found to date.
[size=78%]http://news.nationalgeographic.com/news/2011/07/110726-most-massive-water-cloud-quasar-black-hole-space-science/[/size]
This black hole is nothing more then an accelerator of energy. What gets stripped away from matter is transmitted in every direction from the quasar radiantly with all know frequencies. In fact the emissions from the quasar have tons of x-rays that tend to warm up the water to an extent and keep it flowing around itself. Understand that if we channel enough energy that the humidity will go up in this process. I don't think this will hurt a thing other then correct what we have done so far to our planet. Hopefully. We have to start looking at the whole picture and it should make sense with what we are seeing.
On our own planet we have gone the route of Gasoline. This has increased the mass of the air and changes the ability of the Earth to shed it's energy back into space. We have increased the density of our Atmosphere and changed it's capacity to hold charges. This in turn has increased the charge inside of our world itself. Making it more energetic and causing the disasters we have been seeing on both Land and Air. We consumed and didn't have a care in the world about what we were doing. But there is a silver lining to this disease we call life. We charged the world and now can take that energy back out. If we understand that radiant energy likes to go out then thats the way we should align this process and get work out of it. We can fix this but only if we have wisdom in our direction.
epwpixieq-1
In an open system such as one wire or wireless we are doing the same thing with the exception that we are now connected to nature to form the loop.   Everything is filled with electrons in a scalar form, everything is vibrating at it's natural resonance.   That ringing in your ear - the high pitched ring you can hear but you can't - is your personal frequency.   If you briefly overlap someone else's frequency you have a DejaVu moment with similar thoughts....coincidence or real communication at a natural level?
This is more or less the idea of the post I made, a specific explanation of the connection between several of Tesla's patents and Kapanadze's device ( Tesla's receiver of the energy through the natural medium ):
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg308217/#msg308217
The Wire is the Earth, full of electric waves that diffract and interfere ceating standing wave patterns the can be tapped as Tesla has shown/invented 110 years ago, and Kapanadze duplicated in our contemporary time.
znel
Quote from: epwpixieq-1 on December 26, 2011, 01:58:10 PM
A very enlightened post epwpixeig !   Have you made the connection yet?  What better way to hide a secret than to put it in plain sight, in it's simplest form, that everyone will take for granted.   We get so totally bogged down in the complexity of what he was doing that we tend to overlook the obvious. The forest and trees analogy applies here.  There is one common factor within all his devices after he made one simple discovery, every patent after that exploited this discovery.
forest
Znel , I pointed to one important fact which was ignored here, and I don't know why (maybe because of my ignorance in radio terminology)
Kapanadze clear box device proved that output is converted back from very large floating VAR in system. This is very simple proof. He loaded system with first bank of bulbs then with second one and during each moment there was no diminuition of light power of bulbs hanging amont trees. He then spoked about this effect very clearly explainig that when such situation of applying large load to power station working in idle would happen there would be large problem with balancing power surge. Am I correct ?
I'm quite sure this is very very important ,why nobody was interested to confirm it ?
Hope
Quote from: znel on December 26, 2011, 03:20:08 PM
Agreed!  A aha moment.  We can make exact natural frequencies by placing different elements within a plasma flow.  The rate at which they are consumed is a constant that will set the tone (frequency).
Anyone see the article on making DIY nanocarbon tubes? They have (Caltech) made used DNA to assemble nano tubes into a Field Effect Transistor switch.  Seeing this room temperature process of making nanotubes perhaps is akin to how John Hutchinson makes his crystal batteries work.  Crystal subjected to a shorting could capillary the carbon vapors (made from the heat of the shorting) at a nano scale setting the stage for aligned nanotubes creating a less resistive path for natural wavelengths to pass which in turn would cause a difference in potential.  It could further cause other carbons within the crystal glob to vaporize when shorted and follow the matrix spaces to form more nano tubes.   This just may be the reason the batteries gain strength when shorted up to a certain point.  These nc tubes are super conductive allowing charges to path without restriction and we all know nature loves a free ride (law of conservation).
