Thanks to ALL for your help!!
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 71 Guests are viewing this topic.
xenomorphlabs
Quote from: sergei on September 15, 2011, 07:23:16 AM
In 2011 digital camera makes photos size 640*480? Nothing special in so small pictures. Is it real files from your camera or they were resized?
You might wanna look into the folder called "other" in the .rar archive.
There you find the pictures in .bmp format in around 1600 x 1200 pixel quality among partially unrelated content which for some reason were not put into the "original foto video" folder which by its name would suggest to hold the original pictures.
Hope that helps you.
Jury1
What else do you want to consider the in a photo?
Is obvious,  that "ignition controller"  is not able to light a load 200W.
@Wesley
what power supply used to run the device?
these wires tied up after the start of the device?
stivep
Quote from: Jury1 on September 15, 2011, 09:17:49 AM
@Wesley
He used battery charger for the car the strong one.
There was spark when he touch wires.
After he switched of the device than for the purpose to start it again
first he  open up loop of two  wires touched middle one to the one that was not connected and than splice  first two wires again.Than he touched battery charger.
We my be dealing with one of previous  versions of TK device  without looping of excess of power.
similar to smith device.
now   please check how light bulbs are connected in series or pararel. I did not check it up I'm just coming back to american time after the flight.
If  light bulbs are connected   in series than the higher the voltage the lower the current to achieve the same power.
The tungsten in light bulb will survive very high voltage when current is small.
200V at 1Amp = 400V at 0.5Amp = 800V at... and so on ..so on...
The device was not assembled b y TK.
TK said WE ARE GIVING IT TO THE WORLD.
he said You can even take it with you.'
TK was sick in the bed
TK was not present at demonstration.
the guy who made the device  upon me asking to call TK did not do it saying that TK did not authorized him  to show everything and that they never show it to anyone.He said I will not woke up TK at his illness.
Wesley
i was suspicious but!!!  I DID NOT HEAR ANY KICK OF ANY RELAY AT ALL.
xenomorphlabs
@Stivep:
The lamps are connected in parallel.
They share the node coming from the PVC box and both go to ground.
sergei
Quote from: xenomorphlabs on September 15, 2011, 08:37:56 AM
Thank you, I found this images. Also there is another images in this folder that are not related to TK device.
