Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 90 Guests are viewing this topic.
frantz
Quote from: verpies on September 16, 2012, 06:16:14 PM
Think about it: 10kV in 1ns means 10TV/s slew-rate (yes, that's Tera Volts!).
Do you know of any transistor, diode, spark-gap, thyratron, krytron, sprytron that can switch on and off in 1 nanosecond?
Do you know of any ferrite that is good above 1GHz (reciprocal of 1ns) useful for building a transformer capable of transforming a sub 1ns pulse?
Do you think that multiple serially connected transistors or tunnel diodes avalanche faster or slower than single ones?
Dear verpies,
about what are you writing? ??? :-\
I'm writing with jbignes5 about motor/generator from Tesla patent and you?
verpies
Quote from: frantz on September 16, 2012, 06:42:00 PM
Dear verpies,
I am writing about the reality of creating 10kV sub-nanosecond pulses with transformers, transistors, diodes, spark-gaps, thyratrons, sprytrons, krytrons, etc...
My browser is set to filter-out jbignes' posts.
Last time I checked, this thread was preoccupied with Dally's device and Itsu's replication of it.
The aforementioned device is using sub-nanosecond pulses.
starcruiser
I do not think we require 10kv pulses but more around 300 to 500 volts which could be controlled by IBGT's or MosFETs perhaps. This is what they are putting on to the coax per the diagrams floating about. We need to worry about the freq response of the semi conductors under consideration.
Carl
Ganzha
Replica of DALLY gen is prove that this is fake
http://youtu.be/vfdXtgbzbiM
Dally s device is fake because Dally never  take his device up like here
http://youtu.be/p4nyWQOwRTc
but in his video we could see a lot of stranfe wires from outside of board
Сергей В.
ПривеÑ, Itsu
I know DALLY DEVICE is Full Functional Self Running Free Energy Device and i hope so you will convince yourself soon. Dally continue his work on Second device. Now you know why he can't give precise info about coils coz doing this he must to unwind workable coils.
As ALL OF YOU have seen KAPANADZE'S TROLLS don't sleep at all. They did their dirty jobs. Ask them why they don't try to do own research like you did ??
Why all wait for full and complete schematic when nobody of them want to make own working free energy device with own hands ??
I CAN GIVE YOU A FULL FUNCTIONAL SCHEMATIC OF SOME COMPLICATED CIRCUITS AND PROOF THAT THEY ARE FULL WORKING DEVICES. HOW MANY PEOPLE CAN MADE CHECKED AND VERIFIED DEVICE AND MADE HIM TO WORK FROM THE FIRST TIME ?? OR IN OTHER WORDS HOW MANY YOUR DEVICES WERE WORKED FROM THE FIRST, THEN YOU FINISHED SOLDERING. DO YOU KNOW THAT SOME HI-TECH MICROPROCESSORS HAVE WORKING MISTAKES AND BIG CORPORATIONS HIDE THEIR DEFECTS IN HOPE TO SELL AS MANY AS CAN !! I KNOW FOR SOME VERY SERIOUS ERRORS IN HIGH TECH DIGITAL SAMPLING OSCILLOSCOPES!! WHY NOBODY DON'T SCREAM ABOUT THIS HI-TECH DEVICES AND PUBLICALLY CALL THEM FAKES !! DON'T ANSWER ME, ANSWER YOURSELF !!
Itsu now about DALLY device.
Dally's oscillograph still didn't came so we must wait for oscillograms and measurement of his working device.
I did some little research and find english parts for electronic.
Instead КР1554ЛА3 use quad 2-input NAND gate 74ABT00. КТ926 can be changed with 2SC3264e. Instead КÐ"203А use 1N5408. You can connect in series several diodes for example 4 -10 and more to get Very High Voltage Nano Pulse. For more forward current make a parallel conection on several series diode. You need a very speed oscillograph to catch nano pulses and to calculate rise and fall time of Nano Pulse.
Ferrite Ring Ðœ6000НМ К7mm Ñ... 4mm Ñ... 2mm is good and i think you can find it. Good and Quallity ferrites rings can be found in older multisynch monitors. A teflon PTFE wire also can be found in them.
Some orentational data for coils:
L1 - wind with 0.2 mm - 0.4 mm about 820 turns !!
L2 - wind with 0.6 mm - 1.2 mm about 310 turns !!
L3 - wind with coaxial RG 58 A/U, Z=50 about 40 turns !!
L4 - wind with 2.5 mm - 4mm HV insulated wire or make a good HV insulation between layers.
Diameter of plastic pipe 4.6 - 5 sm.
For ATX find old computer ATX power supplies and try several. DALLY found one usefull from five he have found. So also experiment need to be done here with ATX.
Here is complete PCB of DALLY DEVICE. PCB was doing Bronepoezd from our forum http://realstrannik.ru/forum-strannikov.html
I think it's OK but need to be checked again. Thousand eyes better see than two !! :)
Удачи всеÑ... благ !! :)
