9v Battery on Open TPU?
Started by CTG Labs, June 27, 2009, 04:29:06 PM
wattsup
@CTG Labs
Between the layers at the hind leg, I can see with 98% certainty that there is a capacitor there that is about 1" diameter by 1.5" long. That is why SM only had to put a solid wooden leg, then he bundled all the slack wire there and taped it over the top then to the bottom of the leg then back up around a few times.
Also, on the top part of the circuit board there is what I think is a vacuum tube encased in a metal box. It is about 3/4" square by 1.5" long. You can see it when you look at the circuit board at the lower disk location. The top half is seen at one angle and you can see the bottom half at another angle.
Don't forget also there is a toroid coil that is taped behind the circuit board. The toroid and circuit is the right leg support, then you have the left leg with the removable sheath (convenient for battery changes) and the push button on/off switch on the left coil located between the layers, then you have the hind leg with the capacitor between the layers.
Hope this helps your effort.
wattsup
Added:
Oh yeh, one of the white leads leaving the toroid is going directly to output.
Tito L. Oracion
Quote from: -[marco]- on August 07, 2009, 01:20:23 AM
It is sources not source.
The units started up from one or two nine volt batterys.
Mr. Mark has talked about this.
The other source is the earth's magnetic field.
I have also found it to be the Earth's magnetic field.
Marco.
Hi sir marco
Thank you for correction!  ;)
Sir can you demonstrate how to use this Earth's magnetic field?
how was it made possible?  ???
or if anybody can, please demonstrate it  ;)
i'm really wondering how this thing is being use as a source. sorry i'm new to this method.
God bless
otits
wattsup
@CTGLabs and all
Here is an updated General Topography of the OTPU. It is in block form and sorry for the warped perspective but I wanted to show the components relative to a 3D view.
Notice the toroid is located on the back side of the circuit board. The black band going across the circuit is electrical tape that is used to hold the toroid on the back side of the circuit. The circuit is held by two brackets as you can see the two screws on the top of the top big round speaker terminal connector that he used to put his DM probes. One major major major clue to the toroid now is that given the placement of the toroid on the circuit board that is only held by tape wrap onto the circuit board and by the L-brackets on the speaker terminal, one would expect that given the weight of that toroid that is about 3.5" Dia. by 3/4" thick, knowing something about leverage motion, well you would expect that toroid to simply break the circuit board or create major waving movement as he turned the OTPU over so many times, but it does not. This tells me the toroid is not made of heavy mass otherwise that thing should have broken off with the speed of turning of the OTPU in the demo. Very puzzling.
Also, on the OTPU circuit board is a box with a round hole in the center (upper left) that looks like a vacuum tube square casing. In the FTPU, I think also there is a vacuum tube in the center of the spool. Both OTPU and FTPU used tubes. They only need 3-6 volts to run.
I think at the preliminary or birth stage of the TPUs, SM used vacuum tubes in his first two designs since they could easily be retrofitted inside each build. All you need is pulsed DC feed to the tube and a way to condense the HV output to a more usable lower voltage higher amperage output. That's all the first two TPU's are. Nothing magic, but SM portrayed these as free energy devices while what they were doing is normal but them engineers that did the TPU report had their brains up their ass and could not notice the working basis. These first two TPUs gave SM the initial investments he needed to start living the good life as Jack Durban explained to us. SMs mansion tells the rest of the money money link. Want to keep up the lifestyle, make a new TPU. STPU and 6TPU then the bigger ones.
Cutting away the core of the MTPU means nothing since he knew where he was cutting and showed nothing, because at that position in the core, there is nothing. I think in STPU he used regular tape wrap over the device and the hidden tube melted it away. He then found a new wrapping material for the bigger TPUs that has better heat resistance.
I think in the OTPU the four coil winds or quads are simply a way of wrapping a good enough length of multi strand wire that is only used to condense the HV tube output into lower voltage. That's why there is no winding on the top disk of the OTPU. That's also why only seconds after he put on them two magnets and pushed the on button, then before he lifted the OTPU he gave several hot feels to the lower disk where the 4 coils are. He knew they were going to be hot.
Oh about the two magnets, each of those magnets where placed on small boxes that hold a reed switch. One magnet/reed connects the two left windings, the other magnet/reed for the two other windings. Or, one of the magnets is simply a dud. If that is the case then I would say the right magnet is a dud but makes a better show. lol
Now take the STPU which is his smallest donut design. Look at how the outer tape wrap has melted. Look at the thickness of that TPU and you will understand there is enough room to place a tube in there but you will definitely have to live with the heat produced, enough to melt the tape wrap and more.
I did not label everything in the diagram below because I think guys already know their way around an OTPU. lol
I think @otto is right to say tubes, but if it is tubes, then SM was very definitely in this for the money and created these videos with great care to show something overunity. Remember what the guy said when SM put the 6TPU in his hands. Buzzing noise, vibration. Then SM pulled it out of his hands and gave his gyro shmyro distraction. Well anything that is buzzing and vibrating in your hands will give you a gyro simulated effect. There is nothing major there to even waste time on. Guys here just want to take the simple TPU design to the level of their own imaginations and advanced notions. Way more advanced then the TPU.
I think also that SM came back recently to say I did not ask you guys to spend so much time on this. It is his indirect way of saying look, the TPUs were not working in the extremely sophisticated way you guys have been suggesting and testing during these last years. SM was doing this for the shut up money. He knows his technology will never produce real OU and that is why in his last message he said "we still don't know the extent of danger of this technology". HTF can you spend 10 years with a TPU and not know any more then that. He came back to pull the plug on the TPU and save face at the same time. "I did not tell you to waste so much time". Hmmmmmmm.
I cannot believe that Jack Durban, a high level EE guy could not have seen all this when SM showed him the TPUs. Lame. Very lame.
I think I have enough understanding now to replicate the FTPU. Half of the design is show and distraction. The rings and wound coils do not need to be that way but it looks really snazzy. Snazzy distracts from true function.
wattsup
PS: Question. In Tesla's Ozone Patent shorting device method, instead of being motor rotary type or relay or reed or transistor type, what would happen if you used a pulsed tube with a return diode accross it. lol
giantkiller
@WUp,
Good investigation. I have watched you tear at this time and time again. It is enjoyable, no? Keep at it. I have my own tasks at hand concerning all the designs that I do not give up on.
