Effects of Recirculating BEMF to Coil
Started by gotoluc, July 02, 2009, 06:24:29 PM
poynt99
Hey MH.
I don't have to worry about slow connections, not since about 12 years ago ;) But yeah I remember playing that game too.  ::)
Glad those days are gone  :P
.99
gotoluc
Quote from: poynt99 on August 16, 2009, 12:26:02 PM
Luc.
You can try the 1 Ohm.
The wave forms you saw are correct.
You have a pretty good meter there and it would be nice to use it. So this is what I would like you to do, if you are so inclined: We need to see how your meter interprets certain wave forms.
Does your signal generator have an "offset" function? What frequency are you using from your 555?
What I want to know about your meter is if we give it the following, what will it read out?
Generator  (1kHz)                   | Meter DC-RMS   |  Meter AC-RMS
________________________________________________________
50% duty, 0V-1V (pulsed-DC)
25% duty, ""
50% duty, -0.5V-+0.5V
25% duty, ""
Hopefully one of the two (AC or DC) readings will be correct (I'll crunch the values), and then we'll know which to use across the 1 Ohm current sensing resistor.
.99
Okay .99,
since you have the manual to my meter you know more then I about it.
My SG is a Wavetek 134 and I don't think it has an offset but what do I know :P
The frequency I used on my 555 for the last test was 145Hz
That is about all I have.
Luc
poynt99
Hi Luc.
I found the manual for your 134 Generator here:
http://www.el.bqto.unexpo.edu.ve/tperez/LabME/MWavetek.pdf
It looks like it does have a DC offset control (+/-5V), but it is adjusted from the back of the unit ;)
This is a pretty good generator too. You did well if you got it for $25 ;)
145 Hz? OK, I thought it might be quite a bit higher.
.99
poynt99
Luc,
There is also this if you recall I posted at EF a while back. This is simple and still valid for your recent testing. No special meters required if you do it this way.
QuoteLuc,
Here's a simple circuit suggested by aethertech and similar concept by gyula to ease input power measurements.
I had never tried this before so I PSpiced it up to check against the more direct method.
I'm happy to report that it seems to work quite well. All you need is a couple fairly large electrolytic capacitors and a sufficient wattage 10 Ohm resistor (or close). Connect as shown in the diagram here. If you use a wire-wound 10 Ohm it will filter even a little more.
Take two cheap DC voltage meters (both set on "DC Voltage"), one across R3 to measure the voltage across/current through it (I=V/R), and one across the Vbat point on the diagram to measure output voltage V.
Input power to the circuit is now Pi = V x I
Hope that helps.
.99
gotoluc
Hi .99,
I now see the DC offset ;)... what to do with it is another story :P
Hey, you even know I paid $25. for the Wavetek ;D
Is there anything you don't know ::)
Yes, you're right! I didn't try the capacitor resistor arrangement yet. I'll put it together and test it.
I'll post what I find or a video if it gets good score.
Luc
