German Scientist Posts Complete Free Energy Documentation Online
Started by tomd000, July 04, 2009, 06:50:54 AM
spoondini
Think there's any chance for dr turtur to join this discussion directly?  I could understand why a professor would be weary of posting on such a message board, however there is a community here interested in multiplying his efforts.
blierso
Quote from: Xaero_Vincent on August 02, 2009, 11:31:26 AM
Flathunter,
try this archived link (its dead now):
http://web.archive.org/web/20070831015229/http://www.wireservices.com/n9zrt/live-wire/events/marconi/kitefaq.html
*also*
http://www.google.com/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.only1egg-productions.org%2FAltSci%2FElectrostaticMotors%2FImages%2FAmazing_Motor_That_Draws_Power_From_The_Air_PS_Apr_1971.PDF&ei=l7V1StqaBoKwsgPgw4X8CA&rct=j&q=earth-field+antennas&usg=AFQjCNFsAfnN4YW1cLNKHsaYRuNJsmPaCw
It has information on kite-lifted antennas. Balloon lifted antennas could work as well.
Essentially all this is a very long wire hooked up to a balloon or kite with a needle-like tip at the top. There is danger evolved so be careful and know the local laws--low-flying aircraft, hitting power lines, etc.
It would be interesting to see if a stationary antenna (a long metal pole or rod in the ground) with a sharp mildly radioactive tip could induce ionization current at a much lower altitude (say perhaps 10 or 20 meters or less). Such a design can be on your property and not interfere with air traffic or risk coming in contact with power lines. With some land acreage perhaps an array of these stationary antennas can be hooked up to multiply the power.
This radiant source of electricity can be used power Dr. Turtur's electrostatic motor as well. In this case the power would be free regardless of whether or not his and my rotor harnesses vacuum energy to amplify the output power. Although he's performed measurements and experiments, so unless all his experiments were conducted incorrectly the output power is up to 50x greater or more than the input.
BTW, I wouldn't spend much time on dialectic materials. If you look at Naudin's graph the rotation begins to slow down as the capacitance increases. So while the voltage stays the same and the current is reduced the rotation is reduced as well; its certainly not a way of achieving OU. This is probably why he hasn't experimented with the motors since 1999.
I know for a fact that my father had a long radio antenna wire stretched between our house and the barn. It was a un-insulated copper wire on insulated wooden poles about 30-40 feet high and about 100feet long that had enough voltage to light up a 1.5V bulb when connected between the antenna and the ground. The ground was a big copper rod buried deep in the basement floor. We had a knife switch in the window and we used to ground the antenna every time a storm was coming in case of a lightning strike.
the_big_m_in_ok
Xaero_Vincent said:
..I'm pondering if the vacuum can be replaced by gases or oils with high dielectric properties. Compressed sulfur hexafluoride is a gas used in high voltage application for its high dielectric strength. Certain types of oils are also known for their dielectric properties. Perhaps the electrostatic rotor can be submerged into mineral or organic oils. I'll mention these thoughts to Claus and get his opinion.
@Xaero_Vincent
You might also ask if Claus has heard of this?
http://www.sciencemag.org/cgi/content/abstract/289/5479/611
Transformer manufacturers are trying to get away from SF6, since the daughter molecules it produces can be strong Global Warming gases.
--Lee
lltfdaniel1
Quote from: the_big_m_in_ok on September 13, 2009, 10:20:40 PM
Xaero_Vincent said:@Xaero_Vincent
--Lee
http://energeticforum.com/renewable-energy/4673-think-i-found-some-missing-info-teslas-radiant-energy-patent.html
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lumpyknuckle
We have two of the Super E Baldor 7 1/2 hp motors connected by the shafts. Each motor will run when connected to 110 volts, when we turn on the prime mover the other motor does not act as a generator/alternator and will not produce anything. We configured as Mr Perez did, flashed the coils, but still no juice from the alternator.  What are we doing wrong?
Thanks for any help for this newby.
