A simplified MT 13 ...
Started by iacob alex, July 14, 2009, 02:13:43 PM
iacob alex
         Hi Jim !
   You need no math or a plenty stack of words...
   Imagine that you are living in the Middle Age...
   Imagine that you have a simple stick,bar with a hinged end.
   Imagine that you really have the free will to make it work...
   Imagination is more important than knowledge,because doubt grows with erudition.
   Sure,is more convenient to say "no",than to  move over the things...
                 All the Best! / Alex
iacob alex
        Hi JIm !
    ...can be tested in the most simple manner.
       All that you need is a bar:a long narrow piece of solid material.
       Imagine this bar,to play as a first degree lever ,with two unequal arm.
       The small arm will play the median arm.
       The great arm must have a small hinged part,so to can play greater or smaller than the median arm,due to the hinged part.
       This changing end of a linear bar ,is the "key" of the PM motion problem.
iacob alex
     Hi  Jim!
  I agree with you that ..."there are different ways..." to maintain the CoG on the same side   of  the fulcrum/pivot , as a main condition for a running PM.
  Sometimes,you can perform directly upon CoG as  a "free gravity rolling ",if you look at  :
  www.geocities.com/iacob_alex/Some_Drafts/text018.jpg
iacob alex
        Hi !
  I made a simplification of MT13,you can see it in a simple preliminary drawing.
  You say that..."there is a way your idea can be modified" and..."a weighted lever swing   down and lift one or both weights".
  I agree...so we have:
   -the original :Bessler's MT13
   -the simplified conversion of MT13
   The next step(change) is yours...
  I wish you success!
iacob alex
      Hi  Jim !
We play the same game,but in two different manners:
   -to simplify is one...
   -to complicate,intricate is the other...
But you see,sometimes the less is more.
      All the best! / Alex
