Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
0 Members and 27 Guests are viewing this topic.
electricme
@altrez,
I think you are right here, I get the USGS earth quake reports sent to me automatically emailed just minutes after they occur, but I need a chart logger to see if I can match spikes on the cro, to times of the earthquakes.
http://earthquake.usgs.gov/eqcenter/recenteqsww/Quakes/us2009jiaw.php
If you browse to here, then you need to delve in a bit to let them know to send data your way.
You might get a few per day to twenty or more, just depends on the day.
jim
jeanna
Jim,
My scope is not backlit.
I believe Altrez' is also not. This is the reason the blue sky is better, because the color of the pixels is blue and the reflection from them is brighter than the glare from the surface.
The straw hat helped the day I used it, so I may rig up a pyramid with a hole at the top for camera and see if this could help. Otherwise, I think a beach umbrella or tarp kind of thing might work.
Do you mean that you can see a movie without actually downloading it?
I can see the jpegs like that but not any of the movies.
I hope people are interested enough to look.
Thanks,
jeanna
nueview
hi all
there are many electrical experiments from newton to farnsforth that demonstrate the electrical nature of gravity and the effect of charge on falling bodies.
from some tests i have done it appears there are many possible frequencies. bodies traveling in space travel a straight line unless acted upon charge negativity or dipole action can alter these greatly the tide is a good example but in order for the planet to go around the sun the tension between these charges will rise and fall and can produce tremendous voltage this cycle takes about 15 seconds for the sun to build and correct our orbit so we actually jiggle as we orbit the sum the moon tends to do a push and pull as it orbits us as well and these actions greatly effect our weather patterns on the earth astrologers are realizing this more and more.
also when plate pressure arises there is a radio shift down the dial this accounts for excess electrons in the area decreasing wavelength this is easily noticed on my alarm clock each morning and has been quite accurate over the years and produces unusual cloud patterns when the epicenter is close as it often is where we live.
i have been told that lightning strikes are more frequent in the afternoon and evening but we do not get many storms of this type here in Alaska so someone else will have to check this out dawn is said to be the least for this occurrence. these strikes occur about every few seconds around the globe so would be low frequency unless they demonstrate a joule thief effect and i do not see why they wouldn't i am not sure what the resonant frequency of nitrogen is but am sure it would be the main vibration on a dipole moment.
water is a great negative carrier and very reactive to voltage stress if you look around at the sky in your area you should find areas were the clouds are vaporizing away and at some distance they should be dark grey these denote energy podes on the earth positive and negative i post this because even the sun has magnetic hot spots and if you can find these you may want to align the for an earth battery so as to denote this flow pattern and see what happens it is just something else to keep in mind it was a stubblefield comment and just stuck in my mind i see then allot here and always at the same geographical location.
Martin
jeanna
Alaska!
oo Martin, I hope you will be able to add your results to these data.
jeanna
nueview
i just may try some of these again but my last post made me realize something so i need to build a special JT way out there in concept and no battery just a ground.
charging batteries is my main interest but will help here if i can.
@ Jesus
you did some very impressive work on your pulse motor and you definitely deserve a round of applause you get it from me, because i was trying to do the same but with an induction motor and you gave me some new ideas am still working on this, more Tesla car type things it seems to be more reality than fiction even if others don't get it.
@ IST
would like to see more of your battery charging circuit and three phase driver circuits it is really good work you are doing.
@ all
this group has some of the best people at the site am proud to have met you all.
Martin
