Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
altrez
Quote from: sm0ky2 on July 27, 2009, 09:15:24 PM
@ Altez
How far apart are your electrodes?
i have yet to break the 0.68v barrier with mine
i spaced it out to 7ft or so, but no gains as of yet.
its about to storm here and it seems as if the amplitude of the carrier waves is increased, compared to what it was when no storm present.  the DC base voltage is still the same, but the tri-waves im picking up are going crazy...
1 foot :) If you look closely at the pic you can see the spacing. Its one 10 inch galvanized roofing nail. And foot of copper tube.
-Altrez
jeanna
That is cool! ... Altrez has joined the picture group!
I like that you have the probes at the extreme close distance of 1 foot. We have been trying to sus out the difference the distance makes for a long time.
I just added 20 feet to my distance this year and I have not exceeded the values I got 2 years ago. This kind of thing is hard to get much information on with such other variables as moisture and soil type  etc.
Altrez, were you able to figure out how to get the markers to tell you how high the frequency is?
Mine is usually about 2.3-2.5MHz when the wave is looking like that one.
Mine was up to 2.5MHz today.
I saw your post and went right out. I am trying to match the times of at least one person. I am wondering if the pulses in KY would be the same as WA or the same as AK or even if jim is out and about in AU. If it is seen to be a similar wave on the whole earth or definitely not and only a regional thing then I will just do my readings when it is convenient.
This way if most of the fluctuations are seen to be regional, then if a big pilse comes from far away, we should all pick it up and know that it is on the whole globe.
Anyway I will download and post my pics soon.
My joule thief seems to be taking .2v from the available earth volts but not lighting the leds. I am wondering what I am doing. If I am hooking things up as I should.
Oh well,
good job, Altrez,
jeanna
Pirate88179
Quote from: sm0ky2 on July 27, 2009, 08:06:26 PM
nice find Bill.
kind of goes along with my newest discovery..
i had my capacitor (4.7mF) in parallel with the earth battery, and i as i was messing with it, i noticed the 19 LEDs flashing randomly..  eventually i figured out that it was the act of connecting and disconnecting the cap that sent a power surge through the base resistor and triggered the transistor.
a feat the EB by itself is unable to do.
further experimentation revealed that if i open the positive end of the cap and leave the negative connected to the North side of the EB, that it draws more volts from the AIR than the south side of the EB can charge it.
so im going to experiment with this further, and connect a large array of open-ended capacitors to the north side of the earth battery.
i'll post my results later tonight.
it must have something to do with the single charged-plate drawing an opposite charge from the environment, because the north side of the EB by itself does not register any voltage difference, with respect to AIR.
[Edit:]  Wrong again i am........
i must be picking up some kind of spike-back from the JT coil.
its only occuring when i connect then disconnect the cap from the positive side of the JT. reconnecting again turns on the JT, and lights the LEDs for a moment...
guess i need some sort of switching mechanism here to further experiment.....
Smokey:
Here is a thought....years ago on the EB topic, several folks suggest using one electrode in the ground and an antenna for the other one to catch currents in the air.  I have never done that but...in view of your findings, maybe the open lead of your cap was acting as a small antenna?  Possibly you could put a length of wire up in a tree and hook that to your open cap lead and the other to your north electrode and compare the output?  I have read where folks have used a helium balloon with a small wire coming down from it on one side and an earth ground on the other and, they reported getting good power from it.
As I said, I never have tried this but maybe I should have.
altrez
Quote from: jeanna on July 27, 2009, 09:49:41 PM
Oh well,
good job, Altrez,
jeanna
I have been posting pictures for for awhile :) Have you not seen them? The scope is reading 166.6kH I have the probe attached to the copper and the ground clip attached to the Nail.
You will need a lil over .3 volts with a few mAs to turn on the JT with a low powered transistor. How much current are you reading from your EER?
Thanks!
Take Care,
-Altrez
jeanna
Quote from: altrez on July 28, 2009, 08:46:08 AM
I meant scope pic.
I was melting from the heat and had no patience to check my comments. It will be hot again today!
What the scope reads is what is between the markers, right?
You might have taken the pic then fixed the markers, so I wasn't sure if the markers were in the right place on that wave. Believe me, I know how tricky it is to get a pic you can share.
QuoteYou will need a lil over .3 volts with a few mAs to turn on the JT with a low powered transistor. How much current are you reading from your EER?
I have more than enough volts.
I broke the meter that can read amps and I would have to rig up a 10 ohm resistor to read the amps.
I am sure it is the problem. I had in the microamps most of the time last year.
I downloaded jim's cap idea. I do not have a 1000uF cap but I do have some 47uF caps. That configuration just might do it for me, without blinking too. I can put 2 of them in parallel too!
thank you,
jeanna
