Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
Pirate88179
Quote from: Cosmicfarmer on August 03, 2009, 10:39:24 AM
Thanks for the warm welcome, Electricme.
Its not cheese being made in the moon, its Mochi :-)  I have a pet rabbit up there pounding away...
I am interested to see if power is increased if that "tower" is entrained in the ground. Neat idea but if it works out of the ground then its all galvanic IMHO. Still amazing, but people will want to hook huge loads to it and get dissapointed when it dosn't work. That tower idea would go great in a flashlight body, and instead of changing the batteries, you would have to just get it wet. Leave it in a stream for a while or something.
About stubblefield coils...  How were they wound? in the patent picture it almost looks like each wrap was on top of each other, and when it got to the perimeter, another layer was made (series pancake coils). I tried that and realized it was harder to do then I thought because my steel wire was smaller then my copper... I wrapped felt insulation between everything.  So I made one "pancake layer" and then just wrapped the rest of the coil normal style, with felt layers. 3 layers total. I also need to make a connection from the core too, right?
About pancake vs cylinders... Dr.Stiffler says that a pancake coil slows down the (E field?) to slower then the speed of light while a cylinder speeds it up much faster when being pulsed... The speed up was contributed to capacitance coupling - the power taking a shortcut through a quicker path.    So I was thinking to gather power, wouldn't pancakes be better then cylinders? The wave would impact all wire at once instead of being guided through 1 at a time, giving more amps. The pancake acting as a brake while the cylinder acting as a turbo...
Cheers!
Cosmicfarmer:
Glad to see you made it here from Youtube land.  Welcome.
A quick and dirty explanation of the construction of the Stubblefield coil as we know it from research and studying the patent:
It should be wound on a soft iron core.
Solid copper wire and solid soft iron wire. (bare, no insulation as far as plastic, etc)
Unless you can find cotton insulated wire that does not have teflon inside the cotton.
The point is to have insulation for separation that allows all of the moisture to pass through.
Wind the coil bifilar after insulating the core along its length.  I used strips cut from a cotton T-shirt for this.
There are several ways to do this next step, I will tell you how I did it first.
I wound the first layer on the insulated core bifilar.  When I got to the end of the core, I took cotton string that was the same diameter as my wire and wound it in between the copper and iron wires.  You have to do this twice starting from 2 places to isolate both sides of the wire. (This will make much more sense when you see it)
Then, wrap another layer of cotton insulation over the first layer of wire.  Repeat for as many layers as you have wire and patience to wind.
Some of the other folks took small strips of cotton material and wrapped their wire with it prior to winding.  This is a difficult and, to me, tedious, way of doing this but, we don't have many choices now.  In Stubblefield's time, the wire available was all cotton insulated, and it had only cotton and no other plastic under the cotton.  It would be a breeze to wind coils if that were the case today.
It would be good if you wind your coil so that you end up with all of the wire ends (4) on the same end of the coil.  I didn't do this on my first one and did on my second.  This way, you can bury the coil and just have the top of it sticking out of the ground with the 4 wires exposed for hook-up.
Jeanna and Jim can probably give you more information but, basically, this is what I did and it does work.  We just never followed through and set up the pulsing device which he used (we are not sure exactly how) which is where he got his power from.  I am thinking now that a transistor will do this but, a lot of research will need to be done on that.
Hope this helps.
nueview
HI all
this is just a thought about what i am reading here and have read elsewhere but Jeanna wets her cell or EB every day Volta had to dry his cell to remove moisture so could the charge be moisture related either carried in the vapor that can condense or water as it evaporates since they must be insulated or stand allone what if the inside of the tubes are filled with desiccant or some other form of anhydrous material  or perhaps use solar heating to cause evaporation to See what happens.
water vapor is very sensitive to charge flow through difference of potential.
Martin
PS oxides of metals form diodes two metals of different type can form opposing diodes.
jeanna
Hi everybody,
I was taking some readings for the datalogging thread and I had some interesting shots so I thought I would show you here at this thread... ;D
Cosmicfarmer... perhaps there is too much information on the 2 stubblefield threads, but it is a good thing to read. It might save you a load of trouble or inspire you to more!
At the moment there is a new Stubblefield winder (protonmom) who has just begun winding Stubblefield coils. It might be perfect for you to jump in there right now. That way you 2 will be sharing new ideas born of the older ones, and we will all gain from that.
Nueview, perhaps it is the explanation you gave about moisture, but I think it is about surface area of contact. It is no good to use the ground soaking wet because it takes the readings down to the galvanic only level. When moist, this is not so present so it is possible for the spikes and other movements of the magnetic currents to be seen. But since it is being viewed through electrical devices, via wires, there must be some contact.
Ever have an EKG? even there the process requires a cream on the skin for good contact.
Would anybody like to see my pictures from today.
I had incredible spikes today and interestingly only with the simple probes in the earth not with the other set up that has Stubblefield coils added. I am thinking this means it is coming from the earth since there was no sort of antenna.
dc volts then the captions say what they are. the 303khz pair are wide wave and I didn't bother to move the markers. The 2.22Mhz is real.
These spikes could be the hi bark of the new puppy next door. It could also be the puppy was being bothered by something and was barking.
This does not look like a sound waveform at all, but I want to add it.
jeanna
nueview
  @ Jeanna
  i did not mean to soak the ground as the water impurities would severely reduce the resistance of the earth and pure distilled water has very high resistance by adding an impurity to the water the resistance can be adjusted this should set a current flow to a voltage the more current the evaporation should cause charge carriers to move as in an electrolysis process the water would then be removed.
calcium or some other elements may define the motion of these charges though i do not think this is what you are after but cold fussion does release allot of energy.and even slight warming can raise reaction levels. although this is surely occurring it is the energy flow you are looking for .
i have thought that the earth batteries are interesting as there are copper and gold mining techniques that leach metals from the soil and collect them on rods by use of electric currents this allone shows or gives evidence to the nature metals ability to move in moist ground and these charges can be considerable.
putting all this together i made the previous post.
always
Martin
kamax
Here are my first EB (2 cells) connected to a joule thief. I just add the black cap to have enough power. The led blink because he's too big, with smaller cap no more blink but a low light.
I get ~1.3V with no load and it drop to 0.5V connected to the joule thief.
edit: video: http://www.youtube.com/watch?v=UikDRvySVEI
