Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
kamax
@jeanna
This setup is only for testing, i will make other to see if the lenght/wide of the copper tube give me more power or not to avoid a too big voltage drop when in charge.
For the moment it runs for +3h now wihtout any changes but the long testing setup over the time will begin only when i have finished to try all what i want to test and keep the best one.
@all
I don't know if it's galvanic effect or not, i think i use the same piece for my setup as you except mine is in a pot and not in the "real earth". I'm not sure but if my electrodes are slowly dissolved, i think your electrodes would be dissolved too in the real ground ?
I must admit that my setup works only with a little water, a full dry earth don't give me any output but the amout of water don't change anyting, only a little is enough.
I will report all my future result here with you, i read this forum for a very long time and love what you are doing and be very happy to share something with you.
Cap-Z-ro
" @cap-z-ro,
I am paying attention to those reports. Please keep them coming.
The pulsing you were providing was much slower than the pulsing normally present in the earth, but, or because of this it is helpful. "
The pulse rate that I used was slow and rhythmic...like a I recall in a recurring dream I had as a kid Jeanna.
If you can you give me a rough idea of the pulse rate of the earth, as a starting point it may be of help to me ?
Regards...
Edit:
Another of my wacky cap concepts:
I have this 4 pole cap...1 neg terminal 3 positive terminals, designated 'a' 'b' and 'c'.
I took a black plastic film container...I filled it up with alternate lyers of steel wool and cotton.
I placed a 1 inch toroid on the top.
On top of that, i placed the 4 pole cap.
The 3 poles in order now read .21 vdc, .05 vdc, and .10 vdc.
Weird huh ?
Haven't figured out what to make of it yet.
Regards...
Pirate88179
Quote from: kamax on August 03, 2009, 09:13:13 PM
@jeanna
@all
If you read some of the Stubblefield research, you can see where he says that his coils buried in the ground exhibit no deterioration and will last for many, many years.
I have seen this with my set-up thus far, although it has been only just short of two years, not long enough to tell really.  So, your tests will be helpful for sure.  If you run this for a while and see no breakdown of materials, well, that will tell us something.
I may make a similar set-up for testing purposes myself.  I have said this many times before and I will say it again...no one, that we know of, really knows why this works so, this means we can't really say right now what works and what does not.  The best way is to try.
jeanna
Quote from: Cap-Z-ro on August 03, 2009, 09:19:18 PM
Regards...
When you said keep them coming you are paying attention was that to me?
You read my mind? or did I say I was thinking nobody really wanted to see them?
I am consistently seeing from 2.25Mhz to 2.5Mhz
It is like fractals the wave repeats itself at different resolutions.
The final closest resolution the wave usually undulates. But not every day.
I may post a pic here to show the 2.2-5 Mhz of the wave. This is the little spikes I am thinking we can magnify with inductors. I doubt if either Stubblefield or Tesla were doing that, but youneverknow!
This is from today. No stubblefield so no coils at all, just the cu zn probes. The scope doesn't see a wave at this resolution but it is about 22Khz . I am talking about the big carrier wave. But this is the wave being carried.
And another one from today.
This had the basic C+ and Zn- but at each end I appended a NS coil. OOO cool.
jeanna
sm0ky2
tonight's readings::
up to 25 plastic-coated steel wire coils now
0.85v
7 ma
with two 4.7mF (4700 micro) caps have my LEDs blinking rapidly.
getting real close to "staying on"
think i need to make a better joule thief, mine is garbage compared to some that i have seen.
best so far i think was some kind of "modified fuji circuit", possibly from a television? not sure...
was a PirateLabs video lighting a large flourescent tube from an EB.  (was that you Bill??)
anyhow, i think with these large current ratings im getting, i could do some impressive things with the right joule thief at my disposal....
my next mission is to break the 10 milliamp barrier.
need more steel wire
