Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
0 Members and 36 Guests are viewing this topic.
DreamThinkBuild
Hi all,
This thread is moving fast. Here are the results from my tests.
Measured the EB in the morning 838mv 92ua.
Placed 90 watt solar array on it in reverse charge for an hour readings were 497mv 91ua.
After that I stuck the 90 watt array on to charge rest of the day. Final reading was 1.27v 245ua (lower than before with just 15watts).
Reading in the morning 580mv 82ua.
Seems like after charging the EB the voltage drops below normal then returns to normal a day later. What is interesting is my dirt seems to have a charge limit of 1.3v and around 300ua for my current EB setup. I haven't been able to push it beyond that 1.3v threshold with direct current. Well, tear down the grand opening sign to Worm Emporium, I didn't catch any worms either.  ;)
sm0ky2
@ electricme
its funny, you have been going for volts, and i have been going for amps..
so allow me to shed my experience
to increase the amperage, simply connect all the (-) terminals together, and all the (+) terminals together.
you can do this with the first (-) and last (+) of several sets of series-linked tubes, and you will have both Volts and Amps.
and thus 'usable power'.
hope this helps
sm0ky2
@ Jeanna,
further experimentation has led to the discovery that my "experimental electrodes" aren't doing anything special.
as it turns out, they dont need to be insulated, OR coiled.
in fact - it works exactly the same with soft-steel paperclips.
just bend them straight, and stick them in the ground (-)
copper wire at  the (+) and whalla: 0.7-0.98v ,depending on the moisture: less wet = higher voltage.
they can even be right next to each other (not touching)
i'll play around some more tonight and see if i can get some serious current going on.
Pirate88179
Jim:
Great videos mate! (I love your accent)
So, it does appear that even though you get volts from the cells out of the ground, it is higher when they are in the ground.  To me, that is the difference from pure galvanic and the EER.  I can take a carbon rod and my mag. block and get a potential out of the ground but I have seen that it is much higher when in the ground and aligned the way I have them.
This was a good test to see done.  I thank you for doing that.  Wow, over 6 volts over there!!!  At the rate you are going, you will catch up and pass Kapanadze.
jeanna
Wow you guys kept busy after I turned in last night.
@jim,
That is a great test you did.
I didn't look at all the videos yet, but I think you did not do scope shots.
I would like to see them.
Even if you think they are garbled.
Maybe someone else has the same garble?
Or what if it is very unusual and tells us something?
So, please do a scope shot and upload one a day for the days you are home.
You can leave the probes ready to clip on and turn the scope on taks a pic and that is it.
@DreamTB, Good info.
Sorry about the worm farm.
@Sm0ky2
That is interesting.
I am glad for the experimentation.
I got a couple of ideas from it, thanks.
I took a bunch of scope shots this morning.
And one movie.
I hope you aren't all movied out.
It is very short because I left it in avi format so you don't need to use quicktime. I think you can just watch it?
Please let me know.
It is hard to make it short enough on my 5Mpx camera without compression. So here it is.
1 second short:
jeanna
