Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@Jeanna,
Quote from: jeanna on August 12, 2009, 11:49:31 PM
Check this out.
Hey, where is everybody? Did everybody lose their scope?
jeanna
I still here, that last pic of your scope readings, shows a lot of spikes, now a little back I just noticed your last photo, it shows a waveform which looks like the top of the wave seems to be flat.
I see this effect if I have a LED across the EB output.
I havent switched on my scope for at least a week, emotions still a bit raw folks.
Jeanna, GRIDMAPS, is a very interresting topic indeed, there is a New Zealander, his name is Bruce Cathie, he used to be a airline pilot, he discovered the world wide grid, he made a special program called gridworks which can work out the grids from anywhere in the world. (costs a bit though).
Major buildings, monuments, ancient wonders can be found at the grid cross sections. There are small triangles, larger ones and huge ones.
Some funney energy things happens where the gridlines cross.
jim
Pirate88179
@ Jeanna:
Actually, where I live there is only one grid line going past here.  Where you see those 4 grid lines crossing is actually right about where Stubblefield's farm was located!!  (I am east north east of those intersections)
I noticed about Ed's Coral Castle (As previously mentioned) location too as my Mom lives near there.  This can't be a coincidence can it?
@ Jim:
Good to see you here mate.  I hope things are as well as they can be for you.
jdcmusicman
HI folks ,
Finally got a chance to do me a in the ground EB today ...
I used a 18" copper tube 3/4" and a 3/4" 18" aluminum tube ,lined up N/S
about 10" apart ..
My initial readings in bone dry ground are .61 volts .24 ma  not really much but hoping it will be higher tomorrow ...
I setup another one using the copper ground rod off my power pole and put a 3' alum pipe in the ground 10' away ..Initial readings on it are .76 volts .09 ma...Hope it will get higher to
I did another isolated in a planter pot with a 4"x 2" SS pipe with a 8" alum pipe in the center with plain dirt and drenched it with water ..
My initial readings are .42 volts .56 ma .....
And the other SS/alum one I mentioned before that is over a week old now is still kicking at .66 volts 1 ma  haven't wet it or anything still doing fairly good...
I plan on hooking a cap to the EB one tomorrow and let it charge all day just to see how much I can store up in a 8 hr period or so ...
Thanks Jdcmusicman
jeanna
I posted my scope shots from today on the stubblefield thread, but I do want to report this:
I just got my new tiny meter for reading dc amps. So, I will add this here.
Plain EB - 35.7uADC (1/3 milliamp)
EB with 2 NS generators = 96.4uAdc  (almost one milliamp)
I think you are right about this, Bill. I am getting lower dc volts and more dcmA by adding the extra things on the ends. The amps seen on this meter are dc amps.
No wonder I cannot get even a joule thief to start up. I need one of those maximum caps from the gadget, I guess.
jeanna
edit:
JDMusicman,
Cool.
we posted simultaneously.
How excellent. .61vdc in bone dry for the first day sounds like a winner to me!
sm0ky2
finally got my scope in.
and what i found is quite intersting indeed.
im picking up two strong signals, consistent and precisely 180-degrees out of phase, sinusoidal.
and...
a multitude of weaker signals, at first it looked like only 2, but as i focused in on them, there are several. seemingly inconsistent, and causing a lot of constructive and destructive intereference. This is the cause of the "peaks" you notice in the signal when you are not finely tuned into them all. i am unsure of the source of these signals, they may be comming from many places.
im going to try and eliminate the air-born interference and see if i can clean this up enough to get a few shots.
this scope doesnt seem to have a way to freeze the shot, so i hope my camera can pick up on it.
