Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
tishatang
OK, there you go.  Use Bill's example as a reference when installing the pipes.  The one volt can be increased with a parallel res circuit and the meager amps increased with a series res circuit.  Some benefit may be realized by having the DC bias on top of the AC resonant signal?  Look at it this way.
Our res circuit is our child in the swing you are pushing.  You soon learn to time your pushes with the natural rhythm of the swing.  You are now in resonance.  The DC bias is a strong wind that comes up while you are on the playground with your child.  The wind is in you face.   You find that now you have to push harder because you are fighting the head wind.  But, the swing comes back stronger on its own.  The wind pushes the swing back, adding its energy to the return.
If we were to plot energy vs time, the top of the sinewave would be different than the bottom.  In other words, we used more energy against the wind (positive part of sine wave) than bottom (negative part of sine wave).  This difference in output has been used to explain the Coler device.
See here:   http://rexresearch.com/coler/colerb.htm
Maybe this is part of the reason Stubblefield works?  I don't know.  I look at the one volt difference as the supply voltage necessary to power the res circuits.  Is the one volt there because of capacitance between the plates (my belief) or more like a battery?
What is not common knowledge is that the N pole of a magnet is stronger the S pole.  Possibly, as the earth currents charge up the plates (rods), the N rod with have the higher voltage.  Remember, we have an iron winding to link up to this difference in the magnetic field.
electricme
Pulsing  Transformer in Oil  EXPERIMENT 8)
I don't want to disrupt what tishatang is doing, so I will make just this single post that relates back to pulsing a transformer with a modified AC voltage.
Tonight I took my Transformer, the same setup I used last week and carried out this experiment.
Diode on the active of the primary, the secondary went to a 12v car dash light bulb.
I set the transformer in a ex tuna steel tin, filled it almost to the brim with cooking oil, just about half a litre.
Got my outside temperature probe, attached it to the inside side of the container in the oil, cant find my DMM with Temp probe unit..
Switch on at 8.15pm    VoltagePrimary=240v ac VoltageSecondary=12.3v ac out to 12v5w bulb.
bulb is quite bright.    room temp=27.1deg
Time       Temp      Observations   BULB         Remarks
8.23         35.1c      oil hot          bulb is lit    container is quite warm now
8.24         45.1c      oil hot          bulb lit        container almost too hot to touch
8.25         47.8c      oil hot          bulb lit        container cannot be touched too long too hot
8.26         51.8c      oil quite hot   bulb lit       container cannot be touched any more
8.27         55.6c      oil very hot    bulb lit       container oil has tiny bubbles coming out of the primary and secondaries
8.28         59.2c      oil very hot    bulb lit still OK  container bubbles settling down
8.29         61.7c      oil very hot    bulb still lit container radiating heat now. temp probe came loose WHY
8.30         63.7c      oil vv hot       bulb lit       container radiating more heat. put temp probe back, its vibrating
8.31         67.0c      oil vv hot       bulb lit       container getting even hotter   must be magnetic field doing this
Test magnetic field effect by holding a small iron bar vertically, 2" from transformer I can feel vibrations, they get very strong directly over the transformer itself.
8.32         69.2c      oil is vv hot    bulb still lit oil changing colour slightly, don't know why, more bubbles appearing.
8.33         Missed observation looking at inside of experiment.
8.34         Over 70c  oil in bath is very hot      TEMP Display goes out of order, has reached its limit. Too hot for gear.
8.35         unknown,  oil looking funny             Bulb lit, voltage on across bulb 11.9volts
Can only observe from now on, bulb stays on until 9.04
9.03         oil simmering, violent boiling commenses around active lead below inside of primary and secondary coils
9.04         oil simmering, FLASH OF BLUE LIGHT, slight muffled bang, No sparks, Bulb LIGHT Goes OUT.
9.46         oil container is still very hot, cannot touch for long at all.
               Experiment over.
Result is, a Transformer can heat oil when fed DC pulses from a AC supply when a 1N4004 diode is placed on the primary coil.
The transformer gets EXTREAMLY HOT, transferring the heat to the oil it is subsurged within, surprisingly, the DIODE took the punishment with out failure.
The transformer primary windings failed, so the experiment could not be completed.
The reason is not known at this point in time, why the primary windings failed, as it is still too hot for me to poke my fingers into it. ;D
On the white meter you can see HH:HH displayed, the temperature above 70.00 centergrade has been exceeded.
The meter recovered after the probe cooled down and is OK.
jim
Pirate88179
Jim:
I have to say that this was a fantastic experiment to see.  Well done and with good, solid data collection.  That's over 160 degrees F there Jim. (70 C)  This is way hotter than most folks water heaters are set.  (Mine is set to 110 F)  And, who knows how high it got before the primary failure?  Next time, if there is a next time for this, get a cheapo meat thermometer in the store.  They sell the kind up here that have an aluminum rod and a readout dial on the end.  They cost like $2 here.  I used one on a case once and I calibrated it by boiling water (212 F) and turning the dial to 212 so it was right on.  This made it very accurate in the upper readings area.
Great job.
electricme
Thank you, I am going to re run the experiment again soon, but hope fully with a thermometer with a higher limit.
I have a couple of ELCB units that can be plugged in series with the 240v supply.
I could expect the temp to be a fair bit higher next time, and I might build a proper enclosure to contain any unfortunate incident in case of fire etc, perhaps with a perspex lid (got some of this lying around), with the hinge side from my end for safety, fit it with a lid limiting bar or something.
I also have a fire extinguisher here as backup.
jim
lltfdaniel1
Quote from: electricme on November 04, 2009, 07:54:52 AM
tishatang,
Thank you for the advice on the bamboo line tonight, :D  nice to exchange views with you.
I do agree with your above post in regards to medical stuff, Drs are allowed to poisen us with drugs, BY LAW, Stick needles and hurt us BY LAW, poke tubes into every body opening, but if I go out side and stick a needle into someone, as shure as eggs, I'm history.
Believe me I have seen some very close medical shaves over the last 34 years, I have first hand experience.
Here's an example, 30 odd years ago my wife was crook, the after hours Dr was called, he arrived, we told him she was allergic to a certain medication, he gave it anyway, (smarty pants knew better) he drove away. 10 minutes later my wife went into respiratory arrest, she could not breathe, I gave mouth to mouth while calling the ambulance, then rang the previous Dr, (see a bloke CAN do 2 things at once ladies) the ambo arrives in 5 minutes, the officer took one look at me mouth to mouth breathing her, he raced out and gets the oxygen cyl, and I let him take over, (good thing Im outta puff) a second ambulance arrives, so there are now 2 ambo personal there, the Dr arrives, and shaken like a leaf, gives her the antidote, she comes back to us,  and heads off to hospital half dead, I'm left in shock.
Yep that day I lost my faith in quacks who don't listen to you.
I could write a book full of medical mistakes I have seen, you would laugh or cry, probably do both.
Surgeons are not much better, but really good to fix broken bones, and sewing up skin, not much better for anythin else though, again first hand experience speaks. I broke both wrists twice, I was a bit of a rough boy in my younger years ha ha.
I envy you being able to get alternative medicines so easily, the good book tells us our food should be fruits and herbs, in Genesis, then the gov says, we will ban bananas growing by private people, its happened here,  here you lot the gov says, tip tooth paste, and fluoridated water down your throats, ridin rough shod over all us screaming  and hollering NO NO NO.
Next thing they say chew on all the additives we can't dispose of, we pass laws to make you feel better to say its good to eat poisens, and we will spray the air to keep the sun away (so you can't get vitamin d) and keep you cool, and we will poisen the air you breath at the same time, and so it goes on and on.
To be a politician you have to have a heart of stone, lie with a grin, pretend it was someones elses fault and dip your snouts into the public money trough with lightning passes in parliament for wage rises when everyone else suffers like invalid pensioners who can't get dental treatment unless they have a toothake, and if you complain, you are told off because you didn't toe the official line and get put at the end of the list, and if in hospital got to fight to get the right treatment, and they shuv you out the front door because the back room bean counters say a certain disease takes this long to get better and you are in BIG trouble BIG time for busting their budget because you didn't follow their rule book an get better quickly enough.
They can spend millions to aircondition the top floor wards of a hospital, immediately close this "new" facility to the patients, cram patients on the ground floor, call this a major improvement but it is waste on a grand scale and pretend we the public have a loose screw in the top paddock, don't know we have been lied to and have to accept 3rd world medical standard of care. (I even seen real live mice dooing wheelies ona shiny floors getting away from the nurses)
Soon I will know enough to treat myself of any disease, the best way to avoid the flu is to be a hermit, or live on a island, with a fruit tree, pay no tax, hear no bull, sing out loud, no bad neighbours, fish all you like, swim for a clean up, rub 2 sticks together to make a bon fire, and sleep in a cave for safety with no locks on the doors to keep out the baddies.
Bring out my earth battery tubes and rig up a LED that will give me free light to read overunity foreva.
Now people, I feel so much better after a good winge, Ha ha.
jim
To tell you the truth, the natural stuff is the complete best and as you know overunity electric technology is supressed...do you want to know the equivalent in the medical world?
This stuff..it's called colloidal silver water and it would cure everything and reverse it..it also enhances your bodys cell growth rate by quite a bit and it will completely clean your blood of what should not be there because silver is like programmed by the supreme mind of god if you don't mind me saying..and it will defeat anything bad bacteria and leave the good behind and that means all off bacteria like an off beat cell as you know, anything viral, anything cancer but slower and will act like a second immune system it is too numerous to list here..but yea it is extremely benefical for your body.
http://www.dicksonbiz.com/local/videos/videodirectlink-15.php
In 1990, an astounding discovery was reported at Albert Einstein College of Medicine in NYC by Drs. Kaali and Wyman, resulting in Patent No. 5,188,738 being issued in 1993 entitled "Alternating Current Supplied Electrically Conductive Method and System for Treatment of Blood and/or Other Body Fluids and/or Synthetic Fluids with Electric Forces.". Their research work involved an in vitro & in vivo human Blood Electrification process, which electronically sterilizes the blood, resulting in all known pathogens, including bacteria, viruses, parasites, and fungus, being completely eliminated! Their research had been anticipated 24 years earlier in 1973 with the research involved in Patent No. 3,753,886. Not surprisingly though, due to the stranglehold, that the Pharmaceutical Cartel has in the U.S., this revolutionary clinical data was almost totally suppressed. Other than a few News Articles such as the Science News: Mar. 30, `91 pg. 207, Longevity: Dec. `92/pg. 14, and Houston Post: Mar. 20, '91 /Sect. A-10, plus the Patent No. 5,188,738, there has been a complete BLACKOUT since then in the News Media about this powerful medical technology.
So yes that means all sickness known to man and get rid of it completely at it's roots.
http://100777.com/node/215
Cannabis thc, etc and natural solutions and the reason why herbs solve whatever is because of the silver in the ground which is natural but because of the farming technique...their is a lack of silver in the soil which would mean low and because who have very low silver in their blood stream are the ones who keep getting sick and i have read tons of articles from honest people that say the stuff they add to food is what causes sickness in your body..i mean if it is left completely and utterly natural and you took a bit of this stuff you will be the most healthiest person alive on the planet and will never get sick.
http://100777.com/node/1586
Since it's heaverly suppressed like hell in america you can buy it from uk-cs.co.uk i recommend this because they do the proper colloidal silver.. about 50 usd well this is where i buy mine..as i am in the uk...you may be able to buy from canada or australia.
A bottle of 500ml of this stuff will last you 3 months and 1 or a bit more weeks @ 5ml a day.
There is no overdose on this stuff..i recommend 5ml a day if you are healthy which is plenty for what it does and does extremely well you will find your urine well turn into a water colour but if you are sick then something like 10ml.
Anyways a bit about the vaccine and yes it will spawn the deadly 1918 created spanish flu that killed millions because in the us it is a biological weapon weapon and if i was you i would not even bother takeing it because the aim of these vaccines is to kill people and people have been dieing from the vaccine and in the ukraine they were sprayed and about over half a million are affected by this deadly spanish flu because if you knew about the facts of the 1918 spanish flu well yea blood in the lungs..
Person from mossad said that it is a biological weapon, so did jane burkiminister at the theflucase.com sorry for makeing this go off topic but it is extremely important and yea...really how can something like the so called swine flu that is less dangerous than the normal cold get pushed so much?
Well it is to kill people.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
