Earth Electrical Energy Datalogging Experiments
Started by Pirate88179, July 14, 2009, 09:40:58 PM
electricme
@ tishatang,
I have my tuners out and ready to proceed further.
The coil you posted a few pages back, is 25 turns, should I make this coil with 30 turns, then provide taps between 20, 21, 22, 23, 24, 25, 26, 27, 28, 29 and 30 turns.
With the secondary, this is shown as 100 tuens, should I make this with 120 turns, with taps between 100 and 120?
jim
electricme
@ tishatang,
When I wind the coils, what would you recomend as the core? Air core, Iron lamination core, (as in MOT) or solid iron bar?
I am thinking of paralleling across the tuner, a number of capacitors, what values would you suggest.
jim
electricme
@ the_big_M
Quote from: the_big_m_in_ok on December 03, 2009, 10:15:00 AM
Thanks for your response.  I downloaded a copy of the drawing.  It's very representative of the Bedini motor, with the major exception being the MOT.  Caution with that!  Mechanical setups aren't my forte', but I like the relatively low voltage approach by Bedini.
--Lee
Hi Lee, it is a bedini .
If you go back a few posts, and click on the paper clip, you will see this in operation
I'm just putting it to a different use, see the pic below, Ultra Violet radiation, I can smell the OZONE ha ha
tishatang
@electricme
I would not be a hurry to wind some coils.  I would first use the MOT you have in the ground to see what you get.  Use the secondary first because it will have more inductance and give you a lower freq.  Try to setup up a resonant circuit with the secondary and the var cap.  Slowly sweep with the var cap.  Look for highs and lows with your meter.  If you get nothing, then try the primary coil.  This will change your freq bands.
The MOT can be a crude representation of the Stubblefield EB.  Both are  iron core coils.  It is on record that he had large plate caps as seen in photos.  My feeling is he is using the coils in the buried EB as part of res circuit with those caps.  He had fixed caps and had to tune with another var inductor in series with the EB inductor.  We have the advantage of var caps than did not exist in his day.  When you get some spikes as you tune, try and get the freqs.  If you get no signals, we can add another cap with the var cap and change freq bands.  We should get something.  I will try and draw up a sketch for you.
electricme
@ tishatang,
Thank you for this info, I will begin on it tomorrow sometime.
jim
