Time Traveler Sightings
Started by onthecuttingedge2005, July 15, 2009, 02:01:01 AM
rewards are given by how much you pay attention. it does not matter how much you know.
Jerry
the_big_m_in_ok
onthecuttingedge2005 said:
if everyone was given a time machine then time would run a muck, virtual particles are particles out of time phase.  when you travel time you are out of phase as a standard particle.
Hey Jerry,
That was the point I was getting at.  There must be some way to 1) Control what is being done at any one time, and, 2) Not end up in the Earth's core or in a WWII battle in the South Seas.
Quote from: the_big_m_in_ok on July 25, 2009, 11:26:34 AM
onthecuttingedge2005 said:Hey Jerry,
it is quite easy if you have a spaceship. you have to use the Lotus LASER to monitor your distance from Earth at all times as you follow the Earth Back into time. the Laser would be beamed at low energy so it doesn't start fires on Earth.
the only safe way is to do it from space. if you travel a thousand years into the past the Solar System will be a Thousand years in its previous direction so it is best to just follow either the Earth or follow the sun from a distance at some known safe orbit.
it is crucial that Star Chart software are brought along to give you a map of where things will be at given times, I do have Starry Night Astronomy software that can help with astrological positions and Stars, Planets, Moons.
with the software I can put in a date and it will tell me how the system will be arranged as far back as 10,000 years ago. so any date before that would be risking not knowing the solar systems state and would be taking a chance. sort of flying at your own risk so to say unless the software can be made to go back billions of years and that would do the trick.
10 days travel would bring you back to around 10,000 years ago from what I understand but I can't go into details on it just yet. a thousand days travel would take you back 1 million years into the past. I don't quite understand some things yet but I know how to polarize time but it will not be safe unless I/we have a space ship.
Jerry ;)
the_big_m_in_ok
Hey Jerry,
This conversation is getting interesting.  You remind my of my previous business associates.  They had ideas I had to ask for clarification on a few times.
A couple of points?
The laser light travels at the speed of light as well.  Is this a problem in any way?  Oh, also, can you use tachyons?  They go faster than light.  Actually, they're theoretically nonexistent to science.
... the Laser would be beamed at low energy so it doesn't start fires on Earth. ...
Light intensity varies with the square of the distance.  Twice the distance means 1/4 the light shining at a given distance.  100 times the distance is 10,000th the brightness in intensity.  Unless you have a powerful laser or a new technology, there won't be fires on Earth.
--Lee
Hi Big M.
I already know how to polarize time but I can't discuss it until the appointed time, it doesn't require traveling faster than light, the only velocity I need is to follow the Earth backwards through time, it will be no where near light speed either.
the first age was different than the second age or loop, the first had a different finacial burden, the second burden does not.
I wish I could tell you more but not at the moment till I figure out who is who.
Jerry ;)
