Need Help LOW frequency square wave oscillator circuit needed
Started by magnetman12003, July 20, 2009, 10:36:54 AM
magnetman12003
Hi,
Please review the U tube link below.
I wish to construct a low frequency square wave oscillator that will give me the same results as the function generator shown on the below U tube link.
I plan to use a 12 volt DC 5 amp power supply to power it.  However the degaussing coil I will use is 13 inches in diameter.
Can anyone point me towards a real simple circuit that I can make that will  give me the same inverted square wave the inventor is using? The inventor calls out the setup he used on his funtion generator.
My unit will have to be more powerful as I will be using the larger coil.   All help appreciated.
http://www.youtube.com/watch?v=x-aHeHkQumQ&feature=channel
Thanks, Tom
DreamThinkBuild
Here are some "simple" low hertz circuits but they may have to be fed to a driver section for your high power output.
This will generate a 1.5hz wave on the second stage.
http://www.hackcanada.com/homegrown/wetware/ces/dope/ces_jau_2.html
Or you could always use this other design as a base then tweak the 7555 timing for multiple outputs on 4017.
http://www.redcircuits.com//Page19.htm
mscoffman
check out;
http://www.alldatasheet.com/datasheet-pdf/pdf/67458/INTERSIL/ICM7242.html
These long range timers are essentially an NE555 oscillator
type circuit followed by a divide by 256 set of flip-flops
in one circuit pack. Note: the "part equivalent" table, a little
further down the page. Running this into an IRF511 power
Fet transistor gate pin should do it for having a slow power
squarewave signal.
:S:MarkSCoffman
magnetman12003
Hi All,
I have been given this circuit to look at. What you see has been corrected later by Martin C.  Whats your thoughts on this?
This looks as simple as it gets to construct.
Maybe I can use it on myself if it does not work with the degaussing loop. Ha
I just found out the new 12 inch degaussing loop I bought has a 79 ohm resistance.
http://www.hackcanada.com/homegrown/wetware/ces/ebs_4069_corrected.gif
the_big_m_in_ok
@all,
Have a look at :
http://www.electronic-circuits-diagrams.com/oscillatorsimages/oscillatorckt1.shtml
The circuit can be set up to output a square wave of only a few Hz.
There should be a whole lot more on the 'Web to look at, just by GOOGLing it.
--Lee
