Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
NOTE:
Regarding the post immediately above, having each 'Web address the same(I didn't deliberately do that):
From now on, the patent number and a brief description will be all that's given:
#5,916,172
This transformer has elements of a toroid and might be used in a Joule Thief.
--Lee
the_big_m_in_ok
Quote from: the_big_m_in_ok on October 01, 2009, 11:40:05 PM
#5,939,238
I wonder what effect this thing would have on a Joule Thief?
http://www.google.com/patents?id=XbYYAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,428,886
Both Figs. 5A & 5B plus the 'prior art' Figs. might be usable in a Joule Thief:
http://www.google.com/patents?id=NIdgAAAAEBAJ&pg=PP1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
NOTE:
The number on this patent 'Web address doesn't match the patent number.  Same thing with every one below to the end.  That's the way it copied from the web browser.  I don't know why.  They give different patents when I click on them, though.
Also, 'Web addresses probably won't work if any part of it's in bold letters.  I tried with this address.
#3,305,800
Dual toroid sets in series/parallel configuration.  Try this in a Joule Thief?
http://www.google.com/patents?id=ifxxAAAAEBAJ&pg=PA2&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,114,120
Twisted wire transformer with one coil---filtering or impedance matching, mostly:
http://www.google.com/patents?id=_VpHAAAAEBAJ&pg=PA1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,066,236
Unusual toroid wound on a bolt washer:
http://www.google.com/patents?id=U7ViAAAAEBAJ&pg=PA1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#1,133,750
Both a toroid and a Caduceus coil:
http://www.google.com/patents?id=x_BmAAAAEBAJ&pg=PP1&dq=patent:3731237&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
the_big_m_in_ok
#5,619,172
Might be used with a Joule Thief.
#4,816,784
Wow.  This is generally a microwave RF balun, but can be modified to take in a pole mounted wire pattern for an antenna.
NOTE:
This holds true for just about any coax cable balun system.  The patterns are transferable to a pole or possibly a balloon.
#4,242,651
Two toroids with a 'crisscross' that causes opposing coil turns.
#3,508,171
Another complicated susytem that uses ferrite components and might find use in a Joule Thief.  Very unusual.
#3,037,175
Fig. 4 has the most detailed embodiment.  Unusual toroid.
Note:
With regard to the post above having most patent addresses the same, only the number and a description will be given in the future.
--Lee
onthecuttingedge2005
Hi Big M.
This is my favorite coil setup.
any patents on such coil?
the_big_m_in_ok
Quote from: onthecuttingedge2005 on October 02, 2009, 08:55:38 PM
Hi Big M.
Hey Jerry,
I remember a couple, I think, that look similar.  They would have been used mostly for tuning RF antennae or radio/radar detection section input.
And, toroids, with their unusual electrical properties figured heavily in the designs.  Only a very few were circular coils.
Occasionally, your spacecraft propulsion design descriptions crossed my mind as I researched this information.  I don't know whether any of these patents give you, or anyone else, inspirational ideas, though.
They're here to look up for those who're interested.
Re-edit:
Here you go with an easy one:  Plauson's #1,540,998 has a circular setup mounted on suspended balloons.  It probably wouldn't work, especialy on a gusty day, but I'm sure he thought it was a good idea.
--Lee
