Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
Bruce_TPU
Quote from: teslaalset on June 06, 2010, 10:06:59 AM
wojwrobel,
What kind of core materials did you use?
Any pictures of your setup?
My exact questions also...
wojwrobel
teslaalset
Quote from: wojwrobel on June 06, 2010, 10:28:40 AM
ok this is my setup
Thanks a lot!
Looks like you have ferrite as primary and soft iron sheet as secondary?
wojwrobel
i find it very similar that kapanadz setup it also uses high voltage coil to create a "static enviroment" but on the outside of "working coil", so i think this systems works on the same idea that Heins described in his CA2437745A1 patent so its besicaly lenz less transformer and if you think about it its overunity because that way you can put as many secondarys with load as you can!!!
so i think my setup needs hv windings but underneth working secondary...
wojsciech
teslaalset
@wojwrobel,
If Thanes patent does not specify such specific characteristic that is needed to work according to his intentions, his patent wouldn't be valid.
So, if you think your idea works, than it sure is some completely different principle.
