Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
sigma16
Loads one and two connect to the coil labeled "III":
(In case anyone forgot what this device looks like...)
CRANKYpants
The winding is made of two separate wires wound in opposing directions along an insulating form and connected in parallel at the ends. Since there are the same number of turns of wire in either direction, the magnetic fields of the two wires cancel each other out, so the coil has little inductance.
THIS IS ANALOGOS TO TWO IDENTICAL TWINS IN A ROWBOAT - EACH PADLING IN OPPOSITE DIRECTIONS WITH EQUAL FORCE. THE NET EFFECT IS ZERO MOVEMENT BUT THE FORCES ARE STILL PRESENT.
Vortex1
 dear Sir Mr. Thane Heins
First let me say that I admire your workmanship and your finely crafted and spun coils and theories.
There is just one thing that has been nagging me. It is this:
Why are you burning up drive transformers as you mentioned in Dilbert's Dilemma BITT3.0.mov.
If a normal transformer (your driving transformer) is driving a purely reactive (PF=0) load namely the BITT primary, why does the driving transformer burn up? It looks to be rated at least 150VA.
It should be just an intermediary, reflecting nearly all reactive power back to the line, absorbing only a very tiny amount due to resistive copper and eddy current core loss.
You also mention towards the end of the video of having to end the test because the second larger transformer was beginning to burn up. Why is all this power being burned from the mains? Are these not real Watts being burned in the driving transformer?
These things are just puzzling to me, of course I don't have the insight that you have into the operation of the devices and your theories.
Thank you for your kind reply in advance.
Vortex1
sigma16
Quote from: CRANKYpants on October 26, 2010, 08:30:57 PM
You stated that a magnetic field cannot be used to cancel another magnetic field.  You are incorrect.  Also, the discussion of the vectors implies that if the vectors are opposing and cancelled, so is the force.  This does not imply that all of the energy is cancelled, because it isn't.  A magnetic field is not "energy" itself.  It is only the response to a state of an energy source, and not the source itself.
(hope you like variation 6)
Good questions about the burning transformers.
ramset
Well
I made my living dealing with testing labs
If Thane has an independant Test from an accredited Testing facility stating this device is 100-2700 % efficient
END OF STORY!!
NO LAB NOWHERE Is going to put out a report on their letter head signed by their engineer
stating they did these tests and varified these claims as described ,unless they where willing to bet their reputation on it
PERIOD!!
If you guys think for ONE minute They wouldn't need to varify INPUT over OUTPUT to establish efficiency
YOUR SMOKING SOMETHING!!
Chet
PS
TK
you make your living dealing with test labs!!
Chetkremens@gmail.com
Thanks Grandma
