Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
Yucca
Quote from: stprue on August 27, 2009, 10:57:46 AM
@yucca
Any new news on your set up.  I think it's great!  I have recently read The Free Energy Secrets of Cold Electricity and am now hooked on radiant energy collection.
Hi sptrue & all,
I've got some experiments planned, and I'll make a vid about the findings, stay tuned! I will try and split the bridge into two seperate pairs of parallel diodes (presuming as peter says those grey components are other diodes) like the picture of smiths device and then run two secondary halves through it, this should force half wave oscillation because its setting up two seperate quarter waves about the centre tap.
My device as Ive played with it at the moment has a flavour very similar to Dr Stifflers SEC exciter only in a higher powered mode. It definitely seems to suck electrons from ground, and into the +ve side of the bridge, the difference in efficiency is not slight it is VERY pronouced like 3 times as efficient when +ve node is grounded.
I would love to make some data logger with a microphone to listen to the output gap because I'm now also thinking that the device shows greater efficiency during dawn and dusk, another weird thing. My flyback supply runs real cool, transistor only gets to maybe 50C and so I could run it for several days and look for common behavioural changes through the day, if I see them then its an indicator that the device is interacting with the larger scale environment which is a good sign.
flathunter
Hi Yucca,
Just for your information  - TT Brown found that the electrogravitic effect varied in power according to the time of day or night (I read this in Gerry Vasilatos' book ''Lost Science'').  Definitely worth looking into....
Anyway, good luck mate!
Peterae
Also time of year and when it was pointed to a certain constellation, but cannot remember which constellation
@Yucca
You could record the sound into a wav and then use free spectrum analysis software, bit like some have done on the tpu noises.
You can buy sound recorders here in the uk real cheap that download via usb.
Peter
Peterae
The coil in the clear picture xeno gave us is different to the coil in the poorer pictures the larger outer tube doesnt over hang in the poor pictures, and i keep trying to count the turns in the clear picture and keep comming out at 19 each half, also it looks to me that there is no gap between both half windings in the poor pictures, but the clear pictures there is a 3 turn gap, i am wondering if he took 1 turn off the middle of each coil to tune the new coil.
Or maybe a gap in the middle is beneficial.
Peter
Peterae
xeno
Can i ask how you got the value and rating of the secondary cap, as it is still not clear enough to read in the best picture we have.
The reason i ask is that all the caps i have been looking at for 0.5uf 8kv are massive.
Cheers,
Peter
