Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
turbo
Quote from: Peterae on November 29, 2009, 07:54:07 AM
Thanks guys.
I am not so sure thats speaker wire that he used for his primary, where did you get this info.
It looked very much like HV cable to me which i used, i bought 18awg multi-stranded 16kv wire for my primary.
Peter
Okay i didn't mean speaker wire , but the one that goes from the battery to the amp...
The red one.
Heres a couple of pic's and your righ't Peter it could very well be silicon HV wire used for Neon...since he is using other Neon stuff too.
In any case it does not look like solid wire but maybe it works with both...i hope so  :)
Marco.
Peterae
Hi marco
It's difficult to be sure about the primary wire he used, but in the Investors Weekend video a guy holds up the device with Don his arm pushes on the red wire and it bends easily and when he moves his arm away it goes back to it's original shape and also the coil moves in and out of the secondary coil with ease, i must conclude from this that the wire is extremely flexible in nature, also the wire he uses from the secondary side and caps looks very similar wire although different colours and when you zoom into the wire itself it doesn't look very thick gauge.
I personaly think it is HV wire.
The wire i am using is stranded not solid wire.
Peter
turbo
Peterae
certainly worth covering both angles ;)
I still need to find a nice 47nF 8kv cap if anyone has any ideas?
Are you building this as well marco.
Peter
turbo
Quote from: Peterae on November 29, 2009, 09:27:15 AM
Peter
Yes i am.
But i am also working on P. & A. Correa's  PAGD.
This is a verry intresting device but it involves evacuated tubes, glassblowing etc.
I am also still working on Mark's TPU although that should be finished soon  :)
Marco.
