Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
baroutologos
What you mean Marko? Please elaborate. I posses a ignition coil and microwave Hv diodes. What can i do to see the effect?
Baroutologos
caveman360
Quote from: -[marco]- on December 04, 2009, 05:18:19 PM
It does if you stick in a high voltage diode (or enough 1Kv types in series) right after the ignition coil...
Think in terms like spark can go out, but not in.
Then you pull a big spark to some (free, not connected) metal rod and then you can already feel the radiant energy in the environment.
Marco, please correct me if I'm wrong, but when you rectify AC with a diode, it becomes a (pulsing) DC.
However, it doesn't make much difference because you use the potential to charge your metal rod (and if it doesn't discharge - then that's it, you won't have another spark). Do we call a corona 'radiant energy'?
turbo
Offcource it is a pulsed DC High Voltage discharge when it leaves the diode...
My point was that it's possible to generate the effect while the transformer/ignition coil is AC driven.
Without the diode it does not work or at least it did not work in my tests.
I won't call corona radiant energy.
Corona is concentrated locally around conductors,sharp tips etc. while radiant is spread out in the environment much further and like some sort of invisible pressure.
These are definatly two diffrent things.  :)
Marco.
caveman360
If I may just briefly continue on the Don's concept (in the picture above from his demonstration video from 00:51:30 mark, the comment was that it was 8kV AC that was coming from the hand-held TC, powered by a standalone dielectric testing device with a battery pack - not connected to earth circuit in the building. The TC sparks into a capacitor, with an earth wire sparking on the other side. Assuming, a (good) capacitor is essentially a "blocking device", doesn't allow electrons from one plate to jump through the insulator to the other side - particularly in the open circuit like that on the demo. Don said that what was coming out on the other side of the capacitor was "ambient background energy" that is ready to be picked up. Commercial devices are used in aviation, scooters etc.
pese
