Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
caveman360
Well, to conclude, I've tried this today, didn't work for me. ::)
I used a flyback transformer HV coil with integrated rectifier/multiplier/whatever, - should be minimum 4KV DC (smoothed for the telly screen)  with my own primary and feedback winding, the oscillator powered from 12V DC battery.
HV DC is connected to a spark-gap TC of Don's design, slightly varied, as I did not have exctly same components on hand. A home-made Alu-PVC-oil cap (calculated 5nF) for the primary tank and I did not bother to tune the secondary as it is not loaded yet, and so I did not tune the primary either - my SGap producing just a "disruptive discharge".
Different sources of Don's device description tell different story - coil wire length ratio (1:4), in another source - wire length of the primary is not important (but then you have to tune it with a cap  ??? ) yaman, total gridlock.
Anyway, after some fiddling and coupling, I get same size and strength of spark as in the primary spark gap, on both upper and lower section of the coil against the central tap as well as between themselves - which is good, and safe enough. But...
It doesn't produce the discussed effect - I have no spark on the earth side of a two plate capacitor.
Must check my earth cable and connection tomorrow....
caveman360
Quote from: pese on December 04, 2009, 07:10:23 PM
Do you discussing here from this Mr Smith ?
http://www.zpenergy.com/modules.php?name=News&file=print&sid=1078
Pese
Well, most of the document make sence. And I agree that we spend a lot of money trying to replicate something simple like he claims but never seen working. Obviously, we do need to grasp the concept before trying to replicate something.
However, we watched Kapanadze video of a working unit, and the concept is similar. So we'll keep trying. :D
sparks
    If we form a field of positively charged ionized gas.  This acts as a capacitor plate.  The ionized gas can be caused to remain in the "capacitor plate"  by response of the gas to a magnetic field.  The gas atomic neuclei have a magnetic dipole moment that will align with a magnetic field and any heating of the ions is converted into increased cyclotron frequency about the magnetic field lines.  The magnetic field lines so arranged as to cause the ionized gas to remain in a spatial zone or create a cloud of positively charged particles that are magnetically confined.  A macrospcopic grouping of positively charged ions of billions of ionized atoms results in a very charged up capacitor if one agrees that the Earth is negatively charged or the other plate of the capacitor.  The electrical polarization of the field about this ion cloud is powerful. Lightning storm powerful.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wings
Quote from: sparks on December 05, 2009, 01:03:52 AM
My first test, 8 euro plasmaglobe, aluminium foil, exsaust light tube.
what the next step?
