Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
NTesla
Quote from: FatBird on November 10, 2011, 10:09:15 AM
The spark gap needs to be in series.  Don's schematic shows it in parallel,
but that is wrong.
The schematics I have seen show a primary SG 'in series' because it is acting as a switch per a Tesla coil primary input.
Magluvin
In the doc above, I dont see the caps( laeft side near neon transformer)  that are shown in Dons pic above. I see the spark gap in the pic, a small enclosed capsule(forget the name at the moment) connected to the neon transformer.
Also in the pic, it does look like the sec coils are wound the same direction, cant tell for sure at this angle.
What I get from the doc file is that when the primary fires, the magnetic fields of each sec coil are inline, not opposing, but, if the sec coils were oppositely wound, and connected in the middle, each sec would have the same polarity charge at the far ends in reference to the middle where they are connected. This seems to be an unusual situation, no?
So what might be the interaction of electrical field (outside the coils, in the air) between the 2 coils in this situation. In the doc file, there seems to be some effect between the 2.
I dunno yet. But looking into it.  ;]
You guys are the first I have known to try Dons setup.  Would love to see them.  ;]
Mags
Qwert
minde4000
By reversing one of the coils winding direction sine wave goes:    positive-negative-positive    OR     negative-positive-negative.
Both coils in same direction sine wave goes:                               negative-zero(?)-positive     OR     positive-zero(?)-negative
I will make some more pics and post. Btw here is my bench link:
http://www.overunityresearch.com/index.php?topic=67.0
Thanks guys for that link. Pretty interesting. Who made it up?
Minde
Magluvin
Quote from: NTesla on November 09, 2011, 11:47:16 PM
Here is my initial setup:
NT, well dang, looks like you went through a lot of trouble getting all that  on the table.  ;]  Looks great..    What diagram did you follow?  Seems there are a few out there.
What is the output of your neon transformer? Is it the same as Dons? 2 outs and a common ground( reference ) Man you got the big can caps and all.  Serious.  ;]
Minde,  I dont know who wrote it.  I found it on Emule I believe, then searched for the title and there it was again.
At least it may give us some other ideas to fiddle with if any of Dons diagrams dont add up. Hopefully it gives some things to understand.  Looks like a lot of work put into the doc.
My original doc is in black and white. The link has some color pics, so I know I didnt get it there. But all the same stuff.
Tesla used magnets in the spark gap to blow it out before anything came back through.  Unidirectional, like a diode. So maybe we dont have to use mags these days, since diodes are around.
Dons has diodes on the terminal strip with the rectangular caps. They may be correct in the schematics shown.
His neon transformer seems to be a dual output with a common ground, where the spark gap device is connected.
Is there any close ups of the terminal strip with caps and
diodes?
Mags
