Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
giantkiller
There isn't?
Do you see how simple his builds are? I pushed this 2.5 years ago.
Quote from: xenomorphlabs on July 26, 2009, 10:15:58 AM
There is no constructive discussion possible about this anyway  ;)
Paul-R
Quote from: giantkiller on July 27, 2009, 11:33:13 PM
There isn't?
Do you understand Don's circuits in
http://www.free-energy-info.co.uk/Smith.pdf
Can you reconcile the picture on page 4/92 with the circuit on
page 34/92 (if they belong together)?
Also the necessary circuit to go with the plasma ball.
See also
http://www.free-energy-info.co.uk/Chapter3.pdf
from page 20 onwards.
Paul-R
xenomorphlabs
QuoteDo you understand Don's circuits in
See also
All your answers are in here :  ;)
http://www.overunity.com/index.php?topic=502.0
http://www.overunity.com/index.php?topic=4233.0
Yucca
Hi Xeno & all,
OK, here's what I plan to build fairly soon, exact component values have not been put in yet, some future derivation will include them (especially if I can get it COP>1). I will be keeping the gap breakdown quite low voltage to start with <2kV because my output bridge (10) will be only 20KV rated, but the diodes are bery fast 10nS recovery and the first collector cap (12) is also very fast.
So I can go up to around 5MHz on primary tuning before any dropoff occurs. The coil unit will be  1:4 straight ratio, but if don is correct then the that ratio could well be higher when "magnetic resonance" is achieved.
I think the voltage control shunt (8) is important and R maybe critical? You want to damp the coil (7) ends to force nodes (and thus half wave mag resonance) but not too much so as not to kill any magic? This maybe the only earth reference the cicuit needs.
note:
I cannot replicate dons work, because I don't have the exact components, but this derivation I hope might uncover some exotic effect.
xenomorphlabs
@Yucca : Do you have the possibility to ground your HV transformer (3) too?
I believe that the earth connection at (7) is to provide a way for free electrons to enter the secondary (exactly like in Kapanadze´s secondary). But that`s just in theory.
If you use a variable resistor as indicated in the diagram, then that might work as a current limiter even.
Smith himself has stated that
Quotethe shunt is to generate a better signal
How will you evaluate the output on the cap ? I think you need some kind of load to see the energy in action and to be able to measure the power.
Good to see that you have a go with the device and good luck with building it !
I am also waiting for some more parts and will continue working on mine, which actually is in principle the same device except for the voltage levels
