Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
Yucca
Nice vids flathunter, 1664 is a nice brew ;) I didn´t get round to trying a PFT today, but I will do in the near future.
I picked up some more electrical terminal blocks from the hardware store so now I´ll wind my primary and set up my first Smith like circuit on a thin MDF board. Tuning for now will involve different numbers of parallel 2000pF caps and I will also make my primary be 8 turns and file small tap points onto each turn so I can try soldering the feed on different taps. This should give me quite a few frequency points to experiment with. I´ll be setting up a cap and small gap on the output and counting the fires in a given time. This will give me some relative idea about how well its tuned I hope.
Again I´m thinking the grounding resistor on the secondary coil ends is something that needs careful consideration, I think this might be a vital tuning point, we want to force nodes but we dont want those nodes to be zeros, hence the resistor instead of straight tied.
I think the key is to allow a fairly free swinging standing half wave, this will allow for it to oscillate at fundamental but also at any other frequency at the same time.
Imagine a ruler in free space oscillating at its half wave resonance, well if the ends are on elastic bands instead of anchored then we could also wobble it at much lower frequencies up and down at the same time that it vibrates at its half wave. Difficult to explain, but anyway, if we can get the secondary to generate a large EM field at its fundamental then it may reach out and couple with a large volume of space (like an active antenna).
Through this coupling it may then be able to extract energy from other much lower frequency sources available in that large volume of space like for example schumann resonance which is very feeble at 1picotesla but if you can interact with a sphere of space 10kM radius it maybe a significant power source?
I would really like to get hold of a good variable vacuum capacitor for easy fine tuning, preferably up to 1000pF 5kV, it looks like Russia is the place to buy these at good prices on ebay, next paycheck I may look at getting one.
xeno, I´ve been thinking about that polarised cap... Maybe it´s a diagram error, like he picked the wrong component from his component pallete. It spooks me too. ??? I think the voltage rating shouldn´t matter provided he set the gap to breakdown before max cap voltage is reached.
Yucca
Peterae
Hi Guys
Just got to wait for my order of diodes and caps to arrive now, 10-15 Days :(
Mean time i have just bought a grid dip meter, been meaning to get one for ages, should come in very handy on this build.
Peter
Peterae
Oh one other thing, anyone using Tv or Monitor line output transformers (LOPTX) maybe able to find the pinout of their transformer if you locate the FAT number printed on it, by cross referencing here
http://www.donberg.ie/catalogue/line_output_transformers/konig_line_output_transformers/page_1.html?perpage=1000
Peter
xenomorphlabs
Quote from: Yucca on August 21, 2009, 08:13:30 PM
You have an excellent point with the gap breakdown there. That is the only explanation at least why he might not fry his caps by the sheer voltage level of the NST.
In the 4000 VDC caps device he talks about using lightning protectors as gaps. Not sure what breakdown they usually come with.
On the secondary side of the table device he uses a 10 kV cap across the center tap and the top side of the secondary, which also is rated way too low with a 1:10 winding ratio which will produce voltages between 20kV and 60kV.
The high voltage cables that connect the secondary to the caps are rated at 80kV breakdown, so he runs below 80kV obviously.
If the lightning protector gap is limiting the primary voltage on the cap to 2kV then the voltage across the secondary 10kV rated cap could be just 10kV.
But then the question arises why he used a 9kV output NST instead of a 2kV output one ?!
About the actual oscillation of the circuit, one has to assume that the AC component obviously does not harm the caps for some miraculous reason that we can´t explain yet.
When i first stumbled across that seeming contradiction i assumed that DC caps maybe won`t oscillate at all (together with an inductor) due to their strict polarisation.
However the literature states that they would and likely will get destroyed.
To create any significant RF in the circuit, it has to oscillate (and thus change polarity) somehow  ???
@Peterae: Nice dipmeter! I am sure it will come handy with this type of devices ;)
Keep it up!
