Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
NdaClouDzzz
Quote from: Tesluh on October 19, 2016, 09:54:51 AM
I think I have the primary mostly figured out, was able to bring the voltage in a large cap bank from 0 to 100v in less than a minute.  Not saying I have it all figured out but I have some things working correctly.  after wiring my primary like the video above (paying attention to the direction of the diodes) my spark gap works great and I get sparks across the secondary coil with a screwdriver when the primary is firing.  I have no ground on my primary circuit as of right now.
Can anyone give me a thorough explanation as to how I know if I have resonance in the primary coil or not?  I have made 4 different coils (and will probably have to make more to experiment with) but no way of knowing if they are running at their resonant freq or not.  I have an oscilloscope but have never used one before so I am not experienced in using a scope and don't want to fry it hooking it up wrong.
Better late than never! This should give you some ideas:  https://youtu.be/x-1EKjOtrPM
nix85
I believe Don's devices worked, i only find it suspicious that in that one device he claimed to be ~15kW his output transformer was tiny, like regular 100w transformer. But maybe it was due to high frequency and the fact that he was using cold electrcity that this was possible.
Those photos of japanese vending machines, Coke i think, powered by his devices, are surely not fakes.
Similar success from Russia https://www.youtube.com/watch?v=z2uLBWqqzok
nix85
Few years back i had huge interest in this Don's device, sadly he never revealed how exactly he interrupted the field between two attracting magnets without rotor getting stuck.
Host in the video says it's enough to sprinkle little bit of neodymium dust on a vinyl record which is of course not true. I tried placing 1cm thick neodymiums between bigger neodymiums it had no effect on the attraction of the two big magnets even when placed in opposition to them.
https://youtu.be/tASY07r9AD0?list=UU0tu2-2OJCrmbdyGYzui6jw&t=2946
This ceramic is a solution for this but inventor does not respond to emails
https://www.youtube.com/watch?v=XVcB3mVyZWw
NdaClouDzzz
People tend to forget that OU officially does not exist, and so they forget what Don was up against. Don was fully aware of all of the special interests that he was up against and so he couldn't just give out a working device to the public. At the same time Don needed to make a living and to fund his research. If Don had given the public a working device, what would there be left for him to sell to the big companies? Don needed to keep the public engaged and funding his R&D and so he put out a lot of info that people repeatedly point to as evidence of Don being a fraud. These same people neglect to put themselves in Don's shoes.
For those with the ability to see, Don DID give us the KEY: https://youtu.be/yLjt3y1_ceY?t=4028
https://overunity.com/18238/the-solution/msg535147/#msg535147
efu pdf download: https://download1646.mediafire.com/p8seq3ael1tg/ezikicxbgqvhqmz/EFUSystem.pdf
https://archive.org/details/fav-energenius
https://drive.google.com/drive/folders/1YilkzvdC9c8VFKkh1w5CNCWHarRiffAt
nix85
"there is no connection between the energy on one side and other side" (of the two plate cap), really Don?
Plates are connected to the same HV power source and energy is exchanged between two sides through polarization of the dielectric so there is a connection altho electrons don't pass.
