Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
EMJunkie
You guys are on the right track!
Study this video snippet: https://www.youtube.com/watch?v=EsKoAu_X25A
Study the Right Hand Grip Rule. Study the below Circuit.
Then Study this Video: https://youtu.be/7nc8g-d9kSQ
You are on the right track! Study the Electrical "Generator", the actions are the same. My post Here will help you if you study and replicate.
Best wishes, stay safe and well in these Dire Times,
   Chris Sykes
NdaClouDzzz
Nothing to add, but thank you for your continued efforts👍👍👍👍👍
nix85
Random fact: DC motor is self-regulating due to backEMF, as speed increases backEMF increases and reduces the input current until forces balance.
nix85
I had this idea to pulse high inductance coil with short square pulse, so short virtually no current gets through the coil and then collect the backEMF that develops across the coil but as you can see if you put diode like that to prevent source current bypassing the coil, that diode also blocks the backEMF from the coil which is exact opposite of the source voltage.
nix85
In context of picture above, question is how exactly did Newman, Flynn and Bedini "capture backEMF".
If you let current flow through the coil and then capture the collapsing field backEMF you got yourself a standard boost step up converter. Few posts back i said i believe collapsing field is source of energy, well yea, magnetic field in general is, but how you capture it is essential. Standard boost converter is surely no OU.
I think it's better to capture the first backEMF so that no current from the source ever gets through the coil.
In pure inductive circuit..
