Magnetic Resonance Devices based on Don Smith Concepts
Started by xenomorphlabs, July 25, 2009, 08:00:09 PM
AlienGrey
Quote from: nix85 on September 26, 2020, 04:20:20 AM
Yesterday i been reading a bit old thread from 2007 about Window motor, here is Stephan's drawing of supposedly Neman or Newman like circuit for capturing the backEMF.
It's just full wave bridge rectifier and then a cap in parallel with the stator coil.
Current from the battery is clearly allowed to go into FWBR to charge the cap.
Altho this is very simple circuit exactly what happens is unclear and it depends on that switch in relation to inducing magnet(s).
Maybe Newman took advantage of high inductance coil and delayed Lenz and only closed the circuit at times when Lenz was not breaking the rotor.
Well the simplest way rather than cannibalizing the washing machine to get a water pump could be to use a synchronous cooling fan mechanism and cut a section out of the rotating section and place a NeD magnet in it's place. simple and easy to get hold of.
NdaClouDzzz
Quote from: armagdn03 on November 08, 2010, 06:22:46 PM
Smith has quite obviously not released anything of value.
Dare to open your eyes: https://youtu.be/yLjt3y1_ceY?t=4011   https://youtu.be/oyionE-sCis?t=3205
"On DC you can actually put a load--you can dike this white wire and put in a load. We've had a situation where we've had one hundred and eighty volt DC motor, three horsepower, with Twenty six milliamps exciting--spinning. No load, but it did spin at full 3450 rpm". https://youtu.be/oyionE-sCis?t=3396
nix85
Quote from: AlienGrey on September 29, 2020, 03:09:47 AM
Funny
nix85
Quote from: NdaClouDzzz on September 24, 2020, 02:15:59 PM
Displacement current. He probably thought it was obvious to most.
We all know what displacement current is, regular current "through" a cap
is displacement current, suppose in Don's demonstration other side of the cap
was really connected only to ground. He used a Tesla coil to excite one side of
the cap and Tesla coil is capacitively coupled to ground, even without the cap,
especially so with one which is grounded thus closing the circuit. I am not saying
it is not possible to extract energy this way, all i am saying is that circuit was closed.
