Selfrunning 3 KWatts ERR unit powering 3 x 800 Watt lamps
Started by hartiberlin, July 26, 2009, 11:08:50 PM
powerunlimited
@markdansie,
you have to look beyond what you see to get an idea
whats real or phony.Example in the ERR video the doctor says about connecting with the earth,
well immediately you think hes using the con mans book"How to fool people for proft",ha ha.
He starts the device it begins counting then it locks,then the doctor makes a comment,
funny stuff.
People here react to this in a very nasty way,con man,fraud.You have to look beyond this,
the doctor said that
a special pulse at a frequency has to be applied to get a voltage output,so first step you
sweep across different frequencies to get an idea the range needed to generate voltage,
very easy thing just move the unit around,
when it moves it must have a different locking frequency,next
you make a program using a programable frequency generator.You sample the output voltage
you start at the  beginning of the range of frequencies that gives you the effect,you sample
the voltage, no voltage ,increment frequency
you sample and increment untill a votage appears,then you stop thats the lock.
As for the doctors intention I think that he hopes that he can perfect
the technology and then,open source part of it and sell part of it or lease it.However that
can't happen heres why,He like the tpu's inventor doesn't know how it works,so can't perfect it
thats why its flaky ,only if you know how exactly it works can you perfect it
and limit the bad effects.The right hand ,left hand materials is silly,it takes energy to move electrons
because a material is left hand makes no difference it still takes energy to move electrons.This device
and the tpu are energy converters
they convert an unknown energy source into a different form this is allowed under conventional physics,
they are not free energy devices,
the tpu people on
this site have tried to figure out what it is for years and haven't yet,steven mark the inventor of the
tpu didn't have a clue what the energy source is and  only that it works and said so recently.
powerunlimited
@Harvey
,the point of the post,was that the ERR comes directly
from the rod device the description indicates that a circuit board
was added to pulse the rod device to get more power.
In the rod video the device puts out 18 watts no circuit board,in
power technology's post the modified rod device puts out a lot
more power than 18 watts,more like 300 watts,it also appears that this system was
used in the
device made in japan,the box container hiding the circuit board and other parts.The ERR seen in the video is
coming directly from the rod device its not two technologies but one,the same.
I believe that the device works,I don't believe that the doctor
has a clue how it works,hes doing a trial and error type of
development.Right hand materials or left hand materials you need energy
to move electrons,where is it coming from,the materials he uses are also diamagnetic and paramagnetic.
For this to be real it has to be an energy converter changing one source of
energy to another,not a free energy device.Power technology's post also inicates that
the rod device uses two ring or circular permanent magnets at the base of the rod device,to operate.
The doctor does lie and  manipulate facts however that doesn't make the rod device or ERR any less real.
Harvey
Harvey
@ Powerunlimited,
I had a pretty good look inside that ERR and didn't see anything that resembled a 'nano-tube' rod. I have a packages of nano-tubes right here within arms reach and I don't see any connection between them and the rods. Keep in mind that the post you have quoted made assumptions regarding the rods, perhaps from some of the information provided in the lecture, but still they were just guesses. Those that are jumping to conclusions here and trying to tie the rods in with the ERR are really basing that on a lot of speculation. From what I have seen, and what I have been told, the rods are a completely unrelated technology which has been shelved for cost reasons. If things change where the cost is not a big factor, then that technology may be revisited - after all, old capped oil wells are being reopened because demand continues to increase and it makes running those pumps cost effective to do now when a few years ago it wasn't cost effective.
You made a statement that 'the doctor' lies, could you please clarify that comment?
markdansie
@harvey
I agree with you that I feel the rods and the ERR are not connected. I believe the rods worked but were too costly and eventually ran down. if you like an expensive battery. I fear there may have been other issues like radiation or just plain dangerous materials in them. However I only am guessing.
The ERR is a new kettle of fish. I must admit I am curious to see how it is powered. Has me baffled at the moment.I guess the reason I remain open is the field of left handed materials is still a mystery.
Here is a radio interview. This might give some insights into the man more than the technology.
http://www.achieveradio.com/archplayer.php?showname=The%20%20Progressive%20Technology%20Hour%20with%20William%20Alek&ShowURL=http://audio.achieveradio.com/vortex-net-tech/Dec-13-2008-at-11-00AM---Vortex-Net-Technology.mp3
