Simple 2.5kw power station for boats or home, with solar charger
Started by Tommey Reed, August 06, 2009, 03:29:55 PM
Tommey Reed
I hope I can help you not to make a mistake I did in the past with the pulse generator on OverUnity, they will eat you alive.
Try to test input voltage @ amps and the output voltage @ amps.
This will give you all the data needed to make it more efficient.
Tom...
DreamThinkBuild
Hi Tommey,
:o The final result is it's too in-efficient with this motor setup, the numbers show it clearly.
Results with a 75 watt light bulb run through 2 phase output.
Kill-o-watt measures the input(snow blower motor) loaded 7.67 amp 110vac 720 watt (wow! that is backwards)
Alternator Output measures 146vac 710ma
Results with a 400 watt Quartz Heater. ( ;D 838watts to get a 400 watt heater running)
Input 838 watt 8.53amp 110vac
Output 66vac 1.70 amp
I tried pushing it with a 800 watt heater but the belt started slipping. Too much load and loss with the system.
Tommey Reed
Now you see the devil in the details, very in-efficient. You now see the truth in front of you, no free lunch.
You would be better to have a bigger motor, maybe a 2hp will do to make 1000watts of power.
Sorry that your design did not work the way you wanted it too, I've been there many times.....
Tom....
Tommey Reed
Think of energy, 746 watts of power. This can be more efficient if you calculate the max rpm's and bring it down to 3800-3600 rpms.
In other words, if your motor is running say 10,000 rpm's you can add more torque when you gear in down to 3800-3600 rpm's.
If your not shore how to calculate gearing take 10,000/3600=2.7 or say 3:1 gear ratio.
This will increase efficiency on your unit...
My dc motor runs at 3800 rpm's, with no load.....
Hope this helps..
Tom
Tommey Reed
I see that you are using pulleys, all you would need to do then is calculate the circumference of your motor pulley. (d x Pi) and times the ratio. or say 1:3 would be motor pulley and gen- pulley  (d x pi)  and (d x pi)  x 3.
Tom
