IST! NEO ZAP ARC REACTORS
Started by innovation_station, August 07, 2009, 09:03:50 PM
innovation_station
YEP I FINALLY STARTED A THRED FOR NEO ZAP ..
AND MY ARC REACATORS 814 ... AND THE OTHERS THAT ARE TO COME ...
HERE I WILL LAY OUT THE ENTIRE SYSTEM ...
IM BUILDING A SINGLE UNIT TO LITE AT LEAST 1 60W LITE BULB ...  I WOULD EXPECT MORE FROM A SINGLE UNIT ...  BUT IT WILL LITE A 60 WATT 120VAC BULB TO FULL BRIGHTNESS..
60 W WAS THE LARGEST I EVER TRYED TO LITE ...  IM NOT SAYING IT WONT LIGHT HIGHER WATTAGE BULBS .. IM SURE IT WILL ..  BUT I NEVER TRYED TO ...
MATERIALS
1 COIL LOW INDUCTANCE ON A FERROITE RING ROD WHAT EVER ...
2 NEOS
1 CARBON ROD ..
1 ADAPTOR
ANY WHERE FROM 12VDC 1 AMP TO 30VDC ...
AND THATS ALL FOLKS ....  A LIGHT BULB ... LOL
SURE IT USES POWER ...  SO WHAT !!  ;D
DO NOT USE IRON ....
IT WILL SELF DESTRUCT ...
YOU CAN USE IRON AT THE RIGHT FREQ BUT I LIKE MY THINGS TO RUN FAST AND IRON IS FAR TOO SLOW ... PLUS IM NOT A BIG FAN OF ALL THE HEAT ... LOL
NOW WHY DOES RICHARD WILLIS .... USE OIL TO COOL THE COILS ...  LMAO !!!!
I HAVE NOT FIGURED THAT OUT MY SELF YET ...
I GUESS HE DOSENT KNOW AND THE DRAGONS DEN GAVE HIM 1 MILLION IN FUNDING ... FOR WHAT? SOMETHING HE DOES NOT UNDERSTAND!!!!
LOL LMAO
IST!
innovation_station
I HAVE HAD GOOD RESULTS JUST USEING THEASE AS MY COIL ..
THEASE ARE FROM A MAGNATRON FROM A MICROWAVE ...
IST
CASE AND POINT IS ... ANY PEICE OF FEROITE AND ANY WIRE WILL WORK JUST FINE ...
NOT TOO MANY TURNS THO ....  ;)
rave154
IST,
thanks for the info...can you supply a shcematic by any chance..... im curcious as to "where" the bulb is connected.
i tried my bulb in parallel across the coil, it lit, but only dimmly, no where near as bright as yours, so im guessing that i do not have the bulb in the same place as yourself.
Thanks again
David. D
innovation_station
i will be adding schematics soon ...
i have taped both sides of the neos b4  as showen in the 60w video ..
but i had a real nice plasma ball going in that video
but i have also taped the carbons ...  1 from each side ..   so it can only flow to the bulb ..
also the faster it runs the better ..
i have been trying to find better spark gaps ..
xee2 just suggested spark plugs...   ;D
im a have to try em !
your most welcome !!
W
innovation_station
i have decided to start slow insted ...
it is hard to let the beast run wild and keep from burning things out ......    so do to my laque of any funding ...
i will compleate it as i aquire the more delicate parts to fully build the arc reactor properly ...
but until then i will use it fully controled ..  still let it run wild but in short pulses ...  same can and will be done with the ist sg 36 rof
and now you can use steel core coils   but now this is touching on 2 freqs ....  no NEED FOR PERFECT RESOSNANCE ...   in fact if you find it .... it will blow up your toys ...
so lets stay away from that ...
for now  ;)
im almost done moveing ...  most things are not around me so much so i will use what i have found in my packing process ..  i have a peice of  bronze weilding rod ...  it makes a super blasting sound ..  but it melts if ran in peroids of time ...  so we dont wanna do that .. but i found some things i will use to hold the diffrent spark gaps i will build
ill post pics of all the parts ...
ill build and assemble it tonight
for the carbon rods i found 1/4 " head phone jacks to work well and i got a bunch of them ....
so yea just an up date ...  that i cannot properly build the arc reactor  right now ... verry soon tho ..
ist
