IST! NEO ZAP ARC REACTORS
Started by innovation_station, August 07, 2009, 09:03:50 PM
innovation_station
IVE BEEN DRAWING ERRRRRRR
here is the 555 pulser im useing in my controller
1 555
1 470 resistor
1 led
1 100k pot
1 10 uf cap
ill add the  the fet in the next drawing
if anyone wants to build this with me and post pictures ...  that would be great !!
i found this to work well for me so far  and its simple just a pain to draw ... tho
ist!
rave154
IST,
here is the PWM circuit that i use, its basically the right hand half of the Dave Lawton HHO PWM circuit, works nice because it allows control of both frequency and duty cycle.... but..whatever works to get thing sparking.
rave154
i will just have a cup of tea to wake up properly, and then i will knock up your circuit quickly.
innovation_station
well something happened to my unit ...
dont know what it just keeps poping 555's so ...
yea
i guess ill build a new one i was hopeing this unit was working as the rest are moved already ...
if i can still find my bread board ill whip up a new one make a video and post the pictures on the bread board ..
basically all i think we need for this unit is a small simple pulser .. just to turn off and on the relay thats all recover to recharge source ..
but phase 2 is a bit diffrent more like the arc reactor .. lol
ist
rebuilding
i cant seem to find a 10 uf cap i wanted it to pulse slow ... got lots of 1uf...  but not 10  :(
ill keep looking tho
i think the fet needs playing i was gonna use a bridge where your diode is but you could simply take the diode off the source  and add it to the coil so it fires twice ...  ;D where it flys back into the fet the diode grabs it and rectifies it  but we might need a revrse polarity hook up on the other end of the coil  cuz it will be pos pulse ...
so in effect we use a npn pulse neg to the coil after  we cut the flow it flys back cold ... we rectifiy
it in the diode  then we get a higher voltage positive pulse that can be used on the same coil ..
tic bang   tic (-) bang = cold then diode = hot higher voltage ...  dump to coil . or cap and recharge
bang = returning kick
the pattern would be      - r+ - r+ - r+                               rt= returning pos
now we can do the same with pnp switching ...  and get cold ac ... unrectified ...   ;D 8)
rave154
i have a feelign the 555 is popping cos of a kick somewhere getting back to it.
if its any help, i have another 555 circuit, feeding to an opto-isolator, which in turn fed to an ignition coil, which ran lovely, no HV problems getting back to the 555 at all, completely isolated from it.
